Hey all,
Good info in this thread. Question: I'm thinking of getting the Vac Sys...does everyone just go ahead and buy the "set" (aka pump, SE1 and SE2) or will just the pump and SE1 be good enough for most things? I'd mainly be using it to speed up sanding of parts and for speeding up Domino work. Thanks for the info....
As always with these things, "it depends"...
It depends a lot on what type of work you typically do: is it larger pieces that would need two clamps (doors, etc), or smaller work that would only require a single clamp?
The second clamp, besides offering more holding power for heavier items, theoretically also helps prevent rotation.
The difference in price between the "System" and the "Set" is $385, the SE2 alone is $425, so the Set savings is only $40, which is one of the smaller "set" price differentials in Festool's lineup (the MFT/3 set vs. basic is one of the more egregious in this regard).
My understanding is that the pedal that comes with the SE1/System, when paired with the SE2, runs both pads simultaneously, so when you're using two pads you're always unlocking both at the same time, rather than being able to control them independently. If you want independent control of two pads, I believe you need a second pump and pedal.
The SE2 comes with the oblong pad and the System/SE1 comes with the round pad, so the Set is also a way to get a second pad shape if you want, but it's also something to keep in mind if you think you'd want two of the same pad. The round pad is only sold separately, there is a Pad Set that includes three different oblong pads.
The Vac-Sys is one of the few items not listed on the 2022 price increase list (other than the accessories).
