Author Topic: TS55 REBQ riving knife  (Read 2368 times)
Offline Andrew71
« on: January 11, 2020, 12:29 PM »
Hi, I have just bought a new TS55 REBQ saw, there appears to be a 2-3 mm side to side play in the riving knife, is this normal?
Thank you
Andrew.
Offline Svar
Re: TS55 REBQ riving knife
« Reply #1 on: January 11, 2020, 02:03 PM »
Yes, this is normal.
Offline Andrew71
« Reply #2 on: January 11, 2020, 04:44 PM »
Svar, thank you for your quick reply. Do you know the reason for this? I would have thought there would be little or no side to side play as the riving knife follows the saw blad.
Offline SRSemenza
« Reply #3 on: January 11, 2020, 04:58 PM »
  Just to confirm , yes it is normal. I am guessing that it needs a little play to function without binding and so that it will slip into a kerf easily on a plunge cut.
Offline ChuckS
« Reply #4 on: January 11, 2020, 05:23 PM »
 [huh]Even the riving knife on my SawStop PCS has a little play (flex) (and that's why I aligned the knife with the edge on the right side of the sawblade and not on the left as the installation manual has it).
« Last Edit: January 12, 2020, 08:50 AM by ChuckM »
Offline Svar
« Reply #5 on: January 11, 2020, 11:35 PM »
It consists of several moving parts and it's spring loaded. It pivots around spindel, similar to blade guard on a regular circular saw. One table saw the knife is bolted to the motor assembly.
Offline Andrew71
« Reply #6 on: January 12, 2020, 05:58 PM »
Thank you both for reply.
