Author Topic: Dust extraction for Precisio CS 70 EB  (Read 3812 times)
Offline Ron B.
« on: May 13, 2015, 04:20 AM »
Hello,
Can you advise me as to which dust extractor would be a good match for my Precisio CS 70 EB.  The C1 mini does not seem to be up to the job as there is still a lot of saw dust on and around the saw.  Would the 26 be a better choice or make little difference?
Thanks,
Ron B.
Offline Alex
Re: Dust extraction for Precisio CS 70 EB
« Reply #1 on: May 13, 2015, 04:51 AM »
The current CTL Mini has almost the same suction as the bigger vacs like the CTL 26. Stepping up to the 26 will make a small difference, but not a lot.
I mainly use the CTL 26 with my CS70 and I still find a lot of dust. I just think that a mobile vac is not that effective with a table saw, you need a bigger extractor for that, like a cyclone.
I am almost always outdoors with my CS70, so I can live with some dust. If you're in the shop then Festool vacs just aren't enough to control all the dust.
« Last Edit: May 13, 2015, 04:56 AM by Alex »
Offline Bohdan
« Reply #2 on: May 13, 2015, 05:01 AM »
Ron
Which hose are you using and how long is it?
Offline neeleman
« Reply #3 on: May 13, 2015, 05:06 AM »
I experience the same with my Precisio CS 50 and the CMS-OF.
The main problem lies in the Y-adapter which splits into 2 hoses.
With this the airflow is divided between the 2 hoses and therefore every hose gets less suction.
It depends on the diameter of the hoses how much suction every hose gets.
Try using just one hose on the bottom of the saw or dust cap above the blade.
Festoolian since 1998.
FESTOOL:
ISC 240 | OF1010R | AGC18 | TPC18/4 | TID18 | OSC18 | RTSC400 | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
CHP26 | VCP260 | DSC-AGP125 | DSC-AGP230 | DSG-AGP125 | DRP16
Offline Alex
« Reply #4 on: May 13, 2015, 05:30 AM »
What neeleman says is right, the suction is divided by the Y hose.
I once did an experiment using two vacs, I connected the CTL Mini to the top and the CTL 26 to the bottom of the saw. Dust collection was noticeably better, but still not dustless.
Offline jools
« Reply #5 on: May 13, 2015, 07:51 AM »
On my CMS I usually block off one hose or the other depending on the bit being run. Extract from the bottom when routing dados and from the top when shaping. I'm using a midi.
Jools
It started with one little sander
Offline Caly
« Reply #6 on: May 13, 2015, 01:08 PM »
with my cs70 I use the 36 extractor with the hose and y adapter, I have very little dust if any outside of the saw.
To block the narrow hose.......empty tube  of berroca fits perfect.
