Author Topic: Track Saw Angle Piece for extractor hose  (Read 1449 times)
Offline Samo
« on: November 10, 2018, 11:10 AM »
Assuming these are now only available in the CLEANTEC version 202096?
It's The FOG!  Just rotate the screen.
Offline Peter_C
Re: Track Saw Angle Piece for extractor hose
« Reply #1 on: November 10, 2018, 11:29 AM »
It is not set up like the fitting on the new sanders, and ideally you should be using a D36 hose with your track saw, which means it will go over the top of the fitting. Otherwise a D27 hose fits inside, just like the old fitting that rotates 360*.
I upgraded my saw to one in hopes it would hold the hose in a better position. It does okay at it. Still worth the upgrade.
Offline Samo
« Reply #2 on: November 10, 2018, 12:03 PM »
Thanks Peter!
Offline Peter_C
« Reply #3 on: November 10, 2018, 01:42 PM »
BTW when replacing it remove the screws near the fitting and just past the mid point, but only loosen the ones on the far side. You will be able to remove the old one and slip the new fitting into place without the hassle of dealing with the spring etc on the forward side.
