Author Topic: 50 degree miter with TS 75 EQ  (Read 3391 times)
Offline jjake
« on: May 27, 2015, 05:18 PM »
Is there a way to modify saw for a 50 degree miter? Or, any degree greater than 45?
If not, do you have advice on wedging rail to increase miter?
Thanks, Jim
Offline Doug S
Re: 50 degree miter with TS 75 EQ
« Reply #1 on: May 27, 2015, 06:03 PM »
Think this has been discussed before but can you clamp material vertically to side of a bench  then cut from above at 40 degree (don't know if I got my maths right). Alternatively buy the new festool HKC 55 that's coming out, think it bevels over to 50 degrees  [smile]
Doug
Offline bkharman
« Reply #2 on: May 27, 2015, 08:48 PM »
Thanks, Jim
Can you flip the board over?  You are saying miter but I assume you mean bevel. If the stock isn't too thick (to cut in 1 pass) I would flip it over and cut at 40.
If this isn't what you are chatting about, draw a quick pic.
Cheers. Bryan.
People, I just want to say, you know, can we all get along? Can we get along?
Offline tjbnwi
« Reply #3 on: May 27, 2015, 08:52 PM »
Edge cut.
Offline Holmz
« Reply #4 on: May 27, 2015, 09:13 PM »
...then cut from above at 40 degree (don't know if I got my maths right).
I took my shoe off, and got the same number. [big grin]
The other option is to make a wedge of 5 degrees. The math(s) are:
Sin(5) ~= Tan(5)
So the fat side should be [width*tan(5)] greater than the thin side.
that is '0.087" of rise'/ 'inch of width'
or
'8.7-mm rise' per '100-mm or width'.
I could pull out the FT rail from the MFT box if I 'CBA', but assuming it is ~7" then the fat side will be 0.615" higher than the thin side.
If the wedge was just a strip at the far side then that seems easier than a wedge.
To keep the track from cupping I would suggest a strip under the clamp... You can work it out, but it should be ~3/16 of an inch.
Offline jjake
« Reply #5 on: May 27, 2015, 09:39 PM »
Wow! I think I'm gonna like this group...
I'm miter folding Brookside veneer panels on a reception desk and the angle of the face is 84 degrees to the countertop. Panels too big to edge saw accurately. Love the math for wedging rail! I will look into the "55" saw as my next job involves 50 degree miters (bevels) on 200 panels.
Thank you for all the input,
Jim
Offline tjbnwi
« Reply #6 on: May 27, 2015, 10:05 PM »
With that many panels I'd look into having a router bit made.
