Author Topic: Static discharge issues with Festool Dust Extractors  (Read 4417 times)
Offline sandy
« on: February 08, 2019, 09:23 PM »
I recently designed a very inexpensive, low-profile,  cyclone pre-separator that mounts on, and connects to, a Festool Dust Extractor (See https://www.etsy.com/search?q=festopper ).  A number of comments that I received related to questions about potential static discharge possibly resulting in damage to the Dust Extractor.  Based on all the concern that was expressed about "antistatic" items connected to Festool Dust Extractors, I decided to check my authentic Festool hoses to confirm that they were conductive.  Well... guess what?  They aren't.  Looking at the Festool products, I noted that they specifically refer to their Festool 452877 Non-Antistatic Hose, 1-1/16 In X 11.5 Ft (27 Mm X 3.5 M).  Ya gotta love that... "Non-Antistatic".  Does that mean "Static"?  Anyway, with a Non-Antistatic hose, I don't see why it should matter what's at the other end.  Maybe someone from Festool can clarify that for all of us.
Sandy
« Last Edit: February 08, 2019, 09:33 PM by sandy »
Offline usernumber1
Re: Static discharge issues with Festool Dust Extractors
« Reply #1 on: February 09, 2019, 02:44 AM »
i think thats the cheap hoses. whereis every festool hose is antistatic almost by default, these are the exception hence 'non-antistatic'
Offline Distinctive Interiors
  • Modern Kitchen Specialist
    • distinterior.com
« Reply #2 on: February 09, 2019, 04:21 AM »
Green & Black hoses are Antistatic, Grey hoses are non Antistatic.....452877 is non Antistatic.
« Last Edit: February 09, 2019, 04:24 AM by Distinctive Interiors »
« Reply #3 on: February 09, 2019, 08:22 AM »
@sandy said, “I decided to check my authentic Festool hoses to confirm that they were conductive.  Well... guess what?  They aren't.”
How did you do that?
Offline sandy
« Reply #4 on: February 09, 2019, 08:47 AM »
@Michael Kellough
I used a digital VOM, but the result should not be surprising given Festool ‘s own statement that it’s a “Non-Antistatic” hose.
My authentic Festool hoses are green and black, and they came with my CT22E and CT26E Dust Extractors.
Sandy
« Last Edit: February 09, 2019, 08:55 AM by sandy »
« Reply #5 on: February 09, 2019, 09:14 AM »
@Michael Kellough
Sandy
I’d still like an explanation of how you used the VOM to test the hose. Not sure lack of “conductivity” and “non-antistatic” are the same thing. As I understand it (only a little) static discharge voltage is extremely high but very low amperage. I don’t know the right way to test that.
Also, only the grey Festool hoses are labled non-antistatic. The green/black hoses are called AS as in anti-static.
In use, the gray hoses will accumulate a lot of dust on the outside. The AS hose will accumulate very little dust on the outside.
    • distinterior.com
« Reply #6 on: February 09, 2019, 10:16 AM »
I've found, especially when cutting manmade sheet material, that using a non antistatic Grey hose can give you a static shock when touching the hose during use. Whereas, the Green & Black antistatic hose doesn't produce the same effect.
It appears the effect is mostly prevalent when working with man made materials.
I tend to only use my 50mm Grey hose for clean up on a Building Site with the Tradesman Clean Up kit. The rest of the time, I use the Green & Black hose whilst cutting, routing and sanding.
« Last Edit: February 09, 2019, 10:18 AM by Distinctive Interiors »
Offline Jaybolishes
« Reply #7 on: February 09, 2019, 12:19 PM »
I only own anti static hoses and I also have the Oneida cyclone that fits on my ct36ac.  Twice my electronic module has fried and the kick in the pants is I wasn’t using the cyclone either time and I had the anti static hose plugged into the vac directly. Both times I was sanding wood with my Ets150. Second time out of warranty of course.  Now I use my mini as much as possible because it’s never fried and I use the heck out of it without issue. The cyclone gibberish about it causing static problems is completely bunk IMO.
« Reply #8 on: February 09, 2019, 12:41 PM »
I’ve used the cheap “clear” Dust Deputy with a CT Mini for years with both AS and non-AS hoses without a ground wire between hose and vac with no problem. Also use same stuff with an old Fein Turbo with zero issues.
Offline Bohdan
« Reply #9 on: February 09, 2019, 06:54 PM »
@Michael Kellough
Sandy
A VOM can not be used to check for static leakage as the internal voltage is much too low.
Leakage can only be tested for with a megger, a device specifically designed for this purpose, which generates the high voltage required.
Offline wpz
« Reply #10 on: February 09, 2019, 09:21 PM »
I was curious, so I just tested some of my festool hoses with an insulation tester (a megger) that builds up to 1000V max.
The megger was connected with a crocodile clamp to the plastic bit that goes into the vacuum and I pushed a probe pin onto the inside of the hose at the inlet (past the rubber sleeve that connects to your tool)
my newest green and black 36mm AS flexible hose (the one with the braided outside) starts conducting at about 140V.
my older green and black 27mm AS hose (with the ribbed outside) started conducting at about 180V.
the grey hoses from my CS50 don't seem to conduct at all (the megger build up to 1005V)
I also saw that the part of the vacuum where you plug your hose in is connected to the ground wire of the vacuum's power plug.
What I found interesting is that the rubber end that connects to your tool is non conductive, so the hose is only anti-static past that connection.
So I guess the idea is that static that builds up in the hose by particles that whizz trough and rub against the plastic of the hose gets diverted to the ground (earth) through the vacuum instead of through a person touching the hose.
It might also help to prevent particles sticking to the hose as static can do that (the famous "rub a plastic ruler in your hair and you can attract little pieces of paper with it" test).
So quite clever engineering, these AS hoses (in my opinion).
Could using a cyclone that is not made of conductive plastic damage the electronics of someone's expensive Festool vacuum? I have no idea, but if I designed such a cyclone (or is it a box that holds another manufacturers cyclone that you designed?), I sure would want to know before I start selling a lot of them (and maybe get a good lawyer [big grin])
No offence intended, just trying to be helpful.
Best of luck,
wpz
« Reply #11 on: February 09, 2019, 09:54 PM »
I have a Milwaukee and a Fein vacuum and both have non anti static hoses. Vacuuming anything, wood dust, steel dust, aluminum dust, pet & house dust will all eventually charge the hose and you will get zapped. Just the vacuum function itself will charge the hose. It’s the nature of the beast.
I’ve never had an issue with my CT 22 or MIDI. They both have anti static hoses.
Gray is bad...green & black is good.  [smile]
« Reply #12 on: February 09, 2019, 10:14 PM »
I’m not convinced that the rubber connection is non conductive. If it’s black in color then it’s been carbon loaded and will have some level of conductivity associated with it.
It doesn’t make sense that Festool would carbon load a 20’ hose but cheap-out and refuse to carbon load a 5” long connector. The carbon loaded resin for that connector is less than a buck.
These guys are German designers and I doubt they’d take a chance that utilizing a non-continuous ground path would be a wise long-term decision.
Just my [two cents]
« Last Edit: February 09, 2019, 10:16 PM by Cheese »
Offline wpz
« Reply #13 on: February 09, 2019, 11:38 PM »
I think the plastic housing of the machines that you connect the hose to is also non conductive (the tools don't have a ground pin in their plugs, so don't they have to be double insulated?)
So it would not matter that the rubber end of the hose is non conductive, unless if you were to attach 2 hoses together to make 1 really long one (Is this something you can do with the new hoses with the bayonet fitting?)
The plastic part of the end connector is conductive, just the rubbery part isn't. At least as far as I can measure, but maybe I'm measuring wrong. I'll try again tomorrow and let you know.
Would be nice if someone from Festool could enlighten us.
wpz
« Last Edit: February 09, 2019, 11:48 PM by wpz »
« Reply #14 on: February 10, 2019, 12:25 AM »
Yes it would...[dead horse]
That’s been one of my largest gripes since I’ve joined this forum. A forum owned by Festool that allows technical matters to be answered by ANYONE including MYSELF  while not prompting one of their technical people to interject and straighten things out.
That’s indeed the goofy part of this forum.
Who’s minding the store?
« Last Edit: February 10, 2019, 09:33 AM by Cheese »
Offline Alex
« Reply #15 on: February 10, 2019, 02:01 AM »
The plastic of the tool housing is definitely not conductive, so it doesn't matter if the tool end of the hose is conductive.
The static charge loads up on the hose itself, and all you need is a ground connection to dissipate it. You don't need some round circuit from tool to vac to make that work.
Funny thing is my vac & sander combo works as a ground circuit tester. Sometimes I plug my vac in a socket with grounding and still get zapped from the hose, then I know the building's grounding is not working.
Offline RKA
« Reply #16 on: February 10, 2019, 07:35 AM »
I seem to recall there was an issue with TS55 saws in the UK which had defective fittings for the hose.  The result was static shocks and the fix was a new fitting.  This would suggest both the plastic fitting and rubber hose end do maintain a ground path.
-Raj
Offline Vondawg
« Reply #17 on: February 10, 2019, 10:14 AM »
“That’s been one of my largest gripes since I’ve joined this forum. A forum owned by Festool that allows technical matters to be answered by ANYONE including MYSELF  while not prompting one of their technical people to interject and straighten things out.”
Cheese, I couldn’t agree more with you...I love reading/having these discussions (learning and sharing) from all the diverse members skill sets and their knowledge..but like you say, we have “from the horses mouth” final word, from Festool via the FOG, supposedly available but rarely here from them...leaving us with really... anecdotal experiences ....although pretty good ones, thanks to members.
Offline wpz
« Reply #18 on: February 10, 2019, 10:22 AM »
Just my [two cents]
Well I did some more testing and turns out @Cheese and @RKA were right: the rubber end is conductive!
I connected my hoses to my TS55EBQ (which has one of the newer bayonet connections retrofitted to it) and measured from the blade to the plastic connector at the end of the hose (the side that goes into the vacuum).
With both hoses (the new 36 that fits over the connector and the old 27 that fits inside) a conductive path was there.
Values varied between 300V and 600V, so more than enough conductivety for static which is mostly somewhere between 4000V and 35000V if I'm not mistaken.
Personally I have never been shocked by any of my festool tools, only by some of the prices for parts  [big grin]
I guess those German designers also need to get paid for their cleverness.
wpz
« Last Edit: February 10, 2019, 10:31 AM by wpz »
Offline wpz
« Reply #19 on: February 10, 2019, 10:29 AM »
Some pictures:
« Reply #20 on: February 10, 2019, 12:01 PM »
Thanks 🙏  for posting the photos...very interesting.
Now that you're done with that task  [poke]  your next task is to clean the pitch off of that TS 55 blade.  [big grin]  [big grin]
Offline wpz
« Reply #21 on: February 10, 2019, 12:29 PM »
@Cheese
Sorry 'bout that, my butler Jeeves has gotten very lazy lately  [big grin]
Here ya go:
Offline Peter Halle
« Reply #22 on: February 10, 2019, 12:32 PM »
I am moving this thread into the Ask Festool area.  This is not a tool issue.
Peter halle - Moderator
Offline cgrutt
« Reply #23 on: February 10, 2019, 03:14 PM »
Sorry a little off topic but somewhat related.  I just purchased my first Festool tools including the 36 extractor with green (anti-static) hose.  The HEPA certification was my primary concern driving purchase decision but the anti static-hose was a close second.  About a year ago I was zapped pretty badly (a couple of times) using a shop vac (not Festool) with homemade PVC extension pipe to clean dust off cement floor after grinding adhesives off.  Wow, that discharge sounded like a crack of lightening and hurt pretty badly.  My arms were tingling for several hours afterwards and my hands and finger tips turned white!  Never realized how bad static electricity could get before that and found out the hard way.  I wound up running a copper wire through the pipe and grounded it to vacuum.  I allowed the copper wire to drag on floor.  It helped alot but didn't completely eliminate the static build up.  I'm hoping this new Festool won't have same issue (note I'm not going to use this for concrete dust).  Anyway, very interesting thread.  Learning a lot here...
« Reply #24 on: February 10, 2019, 06:25 PM »
You’ll have no static issues with the Festool vacs as long as you use the green & black hose.  [smile]
Offline TylerC
« Reply #25 on: February 11, 2019, 03:34 PM »
Maybe I'm missing something, but I'm not seeing the specific question here. Can someone clarify the question that you're looking for Festool to answer?
This account is retired. Please address all Festool questions to @festool usa.
Offline SRSemenza
« Reply #26 on: February 11, 2019, 03:49 PM »
Tyler, I think the question has been answered. I think the original question was whether or not the AS hoses were actually AS since the OP's testing result indicated that they were not AS.  However it has been pointed out that a different instrument was actually needed to do the test rather than what the OP had used. Testing with the correct instrument yielded results that the AS hoses are indeed AS.
I am guessing  the OP will chime in with any additional questions.
Offline TylerC
« Reply #27 on: February 11, 2019, 03:53 PM »
That's what I assumed, but I want to confirm.
Offline TinyShop
« Reply #28 on: February 11, 2019, 09:24 PM »
This feels oddly familiar to me, kind of like this particular forum member is once taking advantage of this site and some unsuspecting contributors to exploit people's generosity.
My take on all of this is that owing to the problems that Oneida experienced when they released their Festool-specific Dust Deputy, some sizable portion of Sandy's perspective customers legitimately raised the issue in regard to the Dustopper and its utilization in the design of his "Festopper". Seemingly taken unaware of the potential for issues with static electricity build-up - and rather than fund his own R&D or come clean here about his concern that maybe he's released a product that might fry people's $700 vacuums - Sandy's back here again fishing around for free information that he can use to reduce his liability and beef up his bottom line.
That he was oblivious to the controversy between Thien's baffle and the Dustopper was concerning. That he didn't know the difference between non-antistatic hoses and anti-static hoses (or seem to comprehend the issue of static electricity build-up as a concern in the design of dust separator systems) and that he mocked the language that's used to mark the difference between hoses that won't fry your vac and those that may is alarming. These examples only further reinforce the feeling that I've had along that he's only out for himself. I don't know why my fellow FOGGERs keep falling for his sleazy antics.
Anyone looking for the right way to bring a new third-party Festool accessory to market would do well to avoid using the Festopper as an example and instead look for guidance and a set of roll models from a group of folks like TSO Products or the like. This whole thing stinks.
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline Kevin D.
« Reply #29 on: February 12, 2019, 10:51 AM »
Oooo, I'm glad I bothered to read this far into a thread that I truly have no real interest in.  Just got out of bed today and this post gave me a good wake-up 'spark' to start my day.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
