Author Topic: Planex with CT 26  (Read 1023 times)
Offline abgoto
Planex with CT 26
« on: June 25, 2020, 12:11 PM »
I have a one time remodeling project that will involve hanging ten sheets of drywall.  Given the quote I have received, I can justify in my mind buying a Planex Easy.  I know that the CT 36AC is the recommended vacuum, but I own a CT 26. I also know that drywall dust will reduce the usable capacity of the CT 26 filter bags by 75% and will clog the HEPA filter.  The cost of a new filter and extra bags is still less that the cost of a new vacuum that is only available in a size I do not want.  My question:  Will drywall dust permanently damage my CT 26, or will it just increase my consumables cost?  Thank you for your help.
Offline Alex
Re: Planex with CT 26
« Reply #1 on: June 25, 2020, 01:06 PM »
Drywall dust will not damage your vac in any way. It will also not clog your HEPA filter if you use it with a bag. But it will clog your bag very quickly. So just buy a few extra bags and you're fine. Adding a cyclone in between will help a lot, it will take the brink of all dust you create and make your bag last a lot longer. I bought a cyclone for €30 and build my own reservoir for it from scrap ply.
And ten sheets of drywall isn't really much either. So the amount of dust you wil create is small.
Offline abgoto
« Reply #2 on: June 25, 2020, 02:25 PM »
Once again Alex, thank you for your input. That is exactly the kind of information I was looking for.  An extra pack or two of bags is preferable to a specialty dust extractor that I will rarely need in the future. The Planex will save me so much time over the DTS 400 that I currently use for drywall patches, that the cost is worth it to me.  I will strongly consider a cyclone to reduce the dust passing through the CT.
Offline Peter_C
« Reply #3 on: June 25, 2020, 02:36 PM »
Run what ya got. Change the bag if suction drops off.
A "Dust Deputy" would help. Don't use a HD bucket or other weak buckets. Use the white buckets that cost more, or buy mud in the bucket. Those buckets are good quality.
https://www.amazon.com/Cyclone-Collector-Collection-Separator-Accessories/dp/B081SK39QW/ref=sr_1_7?dchild=1&keywords=dust%2Bdeputy&qid=1593109943&sr=8-7&th=1
Offline abgoto
« Reply #4 on: June 26, 2020, 10:02 AM »
Thanks for the recommendation Peter.
Offline nvalinski
« Reply #5 on: June 26, 2020, 04:01 PM »
Another thought - for just ten sheets, I don't know if I could justify a Planex unless you are selling it after. I have resheetrocked about half of my house running an ETS EC 150/3, and even the ceiling work isn't terrible on a ladder. In the end, it also means that the ETS EC 150/3 is just more useful for me in a woodworking setting than a Planex, plus saves a fair amount of cash even over the easy.
Can't speak to the CT 26 vs 36 AC as I have the AC, but I agree that should be a minimal amount, particularly if you are using a smaller ETS EC 150/3 that requires minimal suction to begin with.
Offline Alex
« Reply #6 on: June 26, 2020, 04:29 PM »
Ten sheets is not much ... I have done jobs like this using only my ETS 125 and DTS 400 together. And it wasn't a lot of work with these sanders. The whole idea is not to apply too much mud in the first place. Three thin coats is better than one thick coat.
I would never try to talk anybody out of buying a nice sander they want, but I agree with nvalinski above, if you buy a Planex for this job, after you're done it's going to lay on the shelf unused. But get a nice ETS EC, and you'll find lots of use for it later on in all kinds of projects.
Offline abgoto
« Reply #7 on: July 07, 2020, 12:17 PM »
I currently use a DTS 400, with my CT 26, and I thought that a Planex would save me enough time to justify the expense. As you have pointed out, if I buy one, I can always sell it afterwards.  Thank you for your input
Offline abgoto
« Reply #8 on: July 07, 2020, 12:23 PM »
I have an ETS 150, and it’s a great sander.  I limit my drywall sanding to a DTS 400, so that in the worst case, I only destroy one sander.  I’m thinking that a dedicated tool for a one time remodeling job may make sense, but I hear you on buying more versatile tools.  Thank you for the advice.
Offline Alex
« Reply #9 on: July 07, 2020, 12:43 PM »
No need to worry about destroying your sander with drywall, that's not gonna happen. All vital parts are well sealed off.
I've been using my RO150, DTS400 and ETS125 for years now with drywall and plaster, and it simply does not affect them in any way. Especially my RO150 has been douched with plaster since it sands so aggressively and the vac can't keep up.
Offline James Carriere
« Reply #10 on: July 07, 2020, 03:58 PM »
Also focus on your taping technique.  A properly applied mud finish needs minimal sanding.  If you are relatively new to drywall then watch some taping you tube videos and do some practice joints on scrap material.  10 sheets is a small job as far as your tools are concerned. A quality applied mud job sanded without a cyclone and a CT26, I estimate 3 bags max due to clogging.  Add the cyclone and it’s one bag.   As for the planex, one benefit that’s not been mentioned in this thread is the 225mm sanding pad will help smooth irregularities in the wall better than the smaller format sanders if your goal is a smooth wall finish. If you are adding texture, flatness is not as critically important. Provided your taping and smoothing coats went well you could probably skip the planex.  There is a small learning curve with the planex which might cancel the time savings on a 10 sheet job vs the smaller sanders you own. . If your job includes a ceiling, by all means get the planex!
Offline abgoto
« Reply #11 on: July 08, 2020, 02:04 AM »
Good to know, thank you.
Offline abgoto
« Reply #12 on: July 08, 2020, 02:09 AM »
I’m decent at taping, but I don’t do it often enough to get really good. About a third of this drywall job with be ceiling, which is one aspect that made the Planex so tempting.  Good to know I am on the right track. Thank you for your input.
Offline Holzhacker
    • www.aic-chicago.com
« Reply #13 on: July 08, 2020, 10:08 AM »
If drywall dust damaged CT's I would have had to buy dozens of CT's by now. Don't listen to whoever is pushing that nonsense. Pull the filters out after doing a lot of drywall sanding, clean them, start again.
My ets 125 has seen more drywall than wood and still keeps on going years and years later. Unless you are really throwing a lot of durabond onto those seams, 10 sheets isn't anything to worry about.
