Author Topic: OF 1400 Universal bushing adapter  (Read 2767 times)
Offline CADru
« on: October 22, 2018, 08:23 PM »
Dropped in my universal bushing adapter the other day for the first time only to find it to be off center with the shaft  [sad]. Don't see any way to  adjust this. The sub (clip catching ring) base has two screws as well as 2 fixed alignment pins. I can visibly see the screw holes for mounting this (sub base ring) part are out of alignment. The other day, at my local Woodcraft store, I saw different sized bushings for the OF 1400. These bushing all have that same integrated clip system as the universal bushing adapter. I thought to myself... "Dang, they're useless"  [sad]
My Ask Festool: "Can this be corrected via service request?"
Offline gnlman
Re: OF 1400 Universal bushing adapter
« Reply #1 on: October 22, 2018, 09:16 PM »
Hi. There are quite a few posts regarding this issue with the OF1400 on this site. I am in the same boat as you with mine. You can do some searching on the subject, but here's a recent thread on the issue. I had not used my OF1400 with guide bushings except for a jig I built to make small circles, which seemed fine, but folks using the OF1400 are finding issues when trying to use jigs to get accurate dog holes....give this a read.
Greg
 http://festoolownersgroup.com/other-tools-accessories/mft-hole-jigs/
« Reply #2 on: October 22, 2018, 09:19 PM »
The real relevant part starts at post 41.  [big grin]   An interesting read.
Offline Svar
« Reply #3 on: October 22, 2018, 09:53 PM »
The irony here is that Festool sells centering mandrels for their routers.
Is bushing holder in OF 2200 and 1010 designed differently?
« Last Edit: October 23, 2018, 04:20 AM by Svar »
Offline Peter Parfitt
  • Magazine/Blog Author
« Reply #4 on: October 23, 2018, 02:32 AM »
You can certainly adjust the OF1010 very easily and it is designed for users to do this.
Offline Svar
« Reply #5 on: October 23, 2018, 04:25 AM »
I take it OF2200 and 1400 are not adjustable.
« Reply #6 on: October 23, 2018, 10:01 AM »
I don't own a 2200 but the 1400 is not adjustable. It just snaps into 2 little pawls and how they hold it is where it sits. The 1010 is adjusted with counterbored screws.
Offline RustE
« Reply #7 on: October 23, 2018, 01:05 PM »
To some extent. I took the advice from your videos and this forum to buy the Leigh 704R. Some folks seem to have difficulties aligning the Festool universal plate.
Offline Svar
« Reply #8 on: October 23, 2018, 01:49 PM »
Seems like the wiggle room for adjustment on OF1010 is minimal. Not sure it was even intended. Oversight of a critical function by designers. Nothing that can't be fixed by the user, but still.
« Last Edit: October 23, 2018, 01:54 PM by Svar »
Offline CADru
« Reply #9 on: October 23, 2018, 08:49 PM »
@Svar
Not to mention the Festool snap in template guides for the OF 1400.
@TylerC
How could this fixed centering alignment issue carry over to RTM? You don't manufacture a tool knowing this issue exists, do ya? The OF 1400 has a feature that is practically useless. My OF 1400 is just 2 years out of box, if you purchase a new one today is this centering alignment still as issue?
Offline CADru
« Reply #10 on: November 09, 2018, 07:42 PM »
The centering mandrel arrived today so I went ahead with my idea for a centering MOD on my OF 1400. I thought if I had access to the mounting screws through the universal adapter I could make use of the centering mandrel. First the alignment pins would have to go (correction: actually "nonalignment" pins in my case). Since the alignment pins were easily removed (pulled them out with my fingers) That was easy, I assumed and thought for sure they would have been press fit into the base. And with the pins removed there is more then enough movement for centering. Next I drilled the access holes for the mounting screws through the universal bushing adapter. Setup the mandrel and centered the template guide. Though I would prefer 3-4 screws to mount the base cause once the alignment pins are removed... 2 screws?...hmmm. Anyway I should get this field tested over the weekend. Looks a promising work around.
Do we  think the two screws alone are enough to hold the adapter centered?
Offline Svar
« Reply #11 on: November 09, 2018, 07:47 PM »
"nonalignment" pins
LOL
Adapter on my Bosch is held by 2 screws. Seems OK. Can you drill and tap additional holes? In place previously occupied by misalignment pins?
« Last Edit: November 09, 2018, 07:49 PM by Svar »
