From the looks of it there are currently no set versions available with the excentric and right-angle chucks on the festoolusa site (for both the T18 and c18 drills).
It appears that the 576457 doesn't come with the centrotec chuck either.
I bought the Dutch version of the TID PDC set two weeks ago, that set does come with the right-angle chuck for the pdc, but no centrotec chuck (I spent quite some time looking for it, I thought I misplaced it, because I was in a hurry to check out the new version of the pdc right angle chuck (my 2008 protool pdc right-angle chuck didn't have the fastfix collet). The Dutch version of that set came with 1 4.0 and 1 5.2 Ah battery and a non-airstream charger.
They made a universal foam insert for the TID combosets. it fits the TID and the C18/T18/pdc18. It isn't the most practical insert, (It was a bit of a puzzle to get the auxiliary handle for the pdc out of its cubby-hole), the spot reserved for the keyless chuck for the pdc is too tight to get it out quickly, so I keep it in the spot normally meant for the excentric chuck for the T18/c18. The bigger versions (like this one) of the new systainer don't have the front carry-handle, but a fixed, lookalike handle that can be used to pull it forward out of a bott-vario drawer I guess.
