Author Topic: kapex 60 degrees to the right cuts the fence  (Read 10696 times)
Offline xylosorus
« on: June 30, 2010, 04:21 AM »
Hello,
I have done some research and didn't find a post on this problem. I hope I didn't miss something.
I had to do a cut with my kapex with the original fences closes to the smallest aperture. The saw was turned to the max : 60 degrees to the right.
At the end of the cut, I was surprised to hear a strong noise and I realized that the blade had cut the tip of the left fence.
I am used to festool great ergonomics. So I was surprised that the fence has let itself go in a position that would allow this.
It seems such a big ergonomic flaw that I am wondering if my kapex has a default, as I would have expected that something (a stop) would prevent the fence to go in such a position.
Is it a known issue ?
Sorry for the bad english.
Best regards to all.
Yann.
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
Re: kapex 60 degrees to the right cuts the fence
« Reply #1 on: June 30, 2010, 05:25 AM »
bonjour [welcome] I don't have a kapex someone will have the answer for you shortly
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Offline woodguy7
« Reply #2 on: June 30, 2010, 05:54 AM »
Welcome to the FOG Yann
I just ran out to the workshop to check mine & you are right.  At 60 deg & the left fence pushed fully in, it will cut it.  I have never noticed that before & i can look out for that in the future.
Cheers, Woodguy.
Shirt size medium
Offline xylosorus
« Reply #3 on: June 30, 2010, 08:06 AM »
Thank you for the prompt reactions and also for the welcome  [smile]
So my saw is not the only one with this problem !
I think it would be a good idea for festool to solve this in the next updates of the kapex and also to issue a warning notice, because it is not good for the blade to go through aluminum ...
Yann
« Reply #4 on: June 30, 2010, 08:56 AM »
Hi Yann I agree, I would have thought it would have been covered in the instruction manual. Have you read it?
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #5 on: June 30, 2010, 09:13 AM »
While not specific, the Kapex manual does say to ensure safe operation, you should check the path of the saw blade for obstructions before making the cut.  The fence is adjustable and can be moved away from the center of the saw into a position that will prevent the possibility of contact with the blade.
From the Kapex manual:
Quote
8 Operation
Risk of accidents
- Before starting work, make sure that the
saw blade cannot touch the stop ruler,
workpiece clamp, screw clamps or other
machine parts.
« Reply #6 on: June 30, 2010, 09:43 AM »
Quote
8 Operation
Risk of accidents
machine parts.
I am not familiar with the kapex but I guess the fence is configured this way to increase practicability over all........ a good argument for making sure you are familiar with your machine.Whatever it is, I know I am guilty just plug it in... off you go... and have a read of the instructions a week later..Then its oh you can do this as well wow...
Offline Jesse Cloud
  • Festooling at the end of a dirt road in New Mexico
« Reply #7 on: June 30, 2010, 09:51 AM »
Yann,
Welcome to the forum.
If you need support near the center and wish to cut a high degree miter, try a sacrificial auxiliary fence made from plywood or mdf.  The moveable aluminum fence has holes in it to accommodate an auxiliary fence.  I made a pattern and use that to make several at a time and dispose of them when they grow small.
Rick Christopherson's supplemental Kapex manual has helpful instructions on how to make an auxiliary fence, including dimensions.
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« Reply #8 on: June 30, 2010, 10:14 AM »
This is neither a defect nor something that should be redesigned. The fence needs to move inward close enough to support workpieces for normal cuts. If the fence position was limited to a clearance position for a 60 degree miter, it would not provide as much support for other positions.
With any tool, it is important to check your setup before making a live cut. Failing to do so is.......well.......normal.  [big grin] I am pretty sure my Kapex has the same shiny cut in the fence that yours does.  [tongue]
« Reply #9 on: June 30, 2010, 10:27 AM »
Yann it sounds as if you've joned an elite club [oops]
« Last Edit: June 30, 2010, 10:29 AM by Festoolfootstool »
Offline Rob-GB
« Reply #10 on: June 30, 2010, 12:57 PM »
Yann, while your fence is sporting a scar, fencing scar maybe [wink], do not worry about the blade teeth too much, they are much harder than Aluminium and if the cut was not made to aggressively, they will have survived nicely. Just do not do it every time. [wink]
In the past I have run Duralium and Brass through panel saws with carbide teeth.... up to 2.4mtrs long!
Now awaiting the HSE brigade to come knocking   [doh]
Also your English is better than my two years of night school French.  ;D
Rob.
Offline jmbfestool
« Reply #11 on: June 30, 2010, 02:24 PM »
YES!    I did a 45 degree compound mitre cut to day and cut into my fence just on the tip because I forgot to move it. I always made sure I move it before I cut but I forgot this time.!!!!     I knew it would eventually happen they should put a digital sensor and tell you your fence is in the position where the blade will catch it. lol   The most annoying thing is it didnt need to do the 45degree cut I was only showing the CLIENT how to do internal corners for skirting because he has been fitting them internal corners with mitre joints I told him its easier scribing them. So trying to do a good thing ended up a bad thing for me.
Its not a fault all chop saws can cut into their fence. The Makita one you can flip the right one over so its out of the way because it has a pivot and the right fence has to be completely removed which is a problem because neither can be adjusted to your piece or angle your cutting at. At least festool you can easily slide both sides to required position according to your cutting angle so you can keep maximum possible support JUST DONT FORGET TO MOVE IT LIKE ME .
I used the companies Dewalt and my mate moved the fence for his cut I didnt realise and I cut the fence right off just like it was butter didnt even know I did it till I removed the timber and saw this metal lying next to it. OOPS!!!!!!
« Last Edit: June 30, 2010, 02:26 PM by jmbfestool »
*********************************************************************** [thumbs up]UK members click me
« Reply #12 on: June 30, 2010, 02:32 PM »
maybe Not as elite as it was this morning [big grin]
Offline richard.selwyn
« Reply #13 on: June 30, 2010, 04:36 PM »
Je les ai enlev?s il y a longtemps.  J'ai les guides suppl?mentaires, donc pour les enlever et les remettre c'est un cauchemar.  Mes excuse pour les faute d'orthographe, je suis un menuisier rosbif en Normandie.
Bonsoir,
Richard.
Offline jmbfestool
« Reply #14 on: July 01, 2010, 02:48 PM »
English please
« Reply #15 on: July 01, 2010, 04:00 PM »
English please
well my french is not up to much nor my English for that matter something about a long time, supplementary guides, a nightmare, being a carpenter,and nit being goo at the written word, living in rosbif,
normandie France
Please correct me
Offline Brice Burrell
« Reply #16 on: July 01, 2010, 04:06 PM »
English please
normandie France
Please correct me
Okay, can someone please translate this English into English. [big grin]
Offline jmbfestool
« Reply #17 on: July 01, 2010, 04:41 PM »
English please
normandie France
Please correct me
Babel Fish not that good.
but its translates to this
I have them enlev? S a long time ago. J' have the guides suppl? mentaires, therefore to remove them and give them c' is a nightmare. My excuse for the fault d' orthography, I am a carpenter rosbif in Normandy
« Reply #18 on: July 01, 2010, 04:52 PM »
Not much better from Google:
I've removed? S long ago. I Supp guides? Comments, so to remove them and put them back is a nightmare. My excuse for misspelling, I am a carpenter roast in Normandy.
Good evening
Richard.
« Reply #19 on: July 01, 2010, 05:09 PM »
English please
well my french is not up to much nor my English for that matter something about a long time, supplementary guides, a nightmare, being a carpenter,and not being good at the written word, living in rosbif,
normandie France
Please correct me
I dont know what happened to my spelling on this [embarassed]..........................sorted
Offline mastercabman
  • NORFOLK,VA
« Reply #20 on: July 01, 2010, 06:46 PM »
Bonsoir,
Richard.
I removed them long ago.  I have the suppllement guides so, to remove and put them back is a nightmare.my apologie for my spelling, i am a woodworker in Normandie.
Good night
« Reply #21 on: July 01, 2010, 06:51 PM »
Bonsoir,
Richard.
Good night
Well done [thumbs up]
Offline Tom Bellemare
  • Inactive Member
« Reply #22 on: July 01, 2010, 11:54 PM »
Sometimes I "Babel en Francais"...
I think he said he was eating roast beef in Normandy while reading maps for a long time - and if you've ever read a European map, you'd understand the Festool user guides.
Hee Hee
Offline xylosorus
« Reply #23 on: July 02, 2010, 06:10 PM »
Festool guide says : "When you are slicing a roast-beef with the kapex, if you are making 60 degrees slices, do not close the fences to the minimum aperture, or there will be aluminum chips in the sandwich".
Thank you all for the attention to this problem.
My conclusion is that I still am surprised that the fences design allows them to be cut by the blade.
I am only surprised because I am used to the excellent INTUITIVE ergonomics of festool and I am convinced that on the next update this will be fixed, because it is only the very tip of the fence that gets ground. So if the aluminum was molded differently the minimum aperture could stay the same (almost) and the fence not being on the way of the blade.
Yann.  [smile]
