Author Topic: Kapex 120 REB bed height  (Read 1278 times)
Offline DynaGlide
« on: April 10, 2021, 02:43 PM »
Am I going crazy or did they change the bed height on the new Kapex REB model to 110mm? The little rubber feet aren't in dog holes when I take the measurement. I wanted to use a Sys 1 as infeed/outfeed until I get the extension wings but the Sys 1 TLOC on my bench is 112mm and the Kapex is 110mm.
Instagram @matts.garage
Offline guybo
Re: Kapex 120 REB bed height
« Reply #1 on: April 10, 2021, 03:03 PM »
Hi this is mine . guy
Offline DynaGlide
« Reply #2 on: April 10, 2021, 03:10 PM »
Hi this is mine . guy (Attachment Link)
@guybo Hey Guy is that with the feet in the dog holes? If so that would confirm what I have since the feet usually drop it 2mm.
Offline guybo
« Reply #3 on: April 10, 2021, 03:18 PM »
Hi, out,2010 model.guy
Offline Dr. P. Venkman
« Reply #4 on: April 10, 2021, 04:13 PM »
I'm not qualified to answer the first part of that question, but I'm pretty sure the answer to the second part is yes.
Last night, I mounted my new Kapex in the miter station I'm building, and I had to raise the shelf slightly higher than I was expecting because at 111mm, the Kapex was below the adjacent counter tops.
After I found that my shelf was too low, I took the Kapex out and put a straight edge across it and a SYS 1, and sure enough, the SYS 1 was taller.
I ended up putting the shelf around 109, and it works perfectly.  I will add here that those little rubber feet aren't hard rubber, which was really convenient.  I finished leveling the shelf really close to 109mm below the benchtop (it might have been 108.75), and the Kapex was very slightly taller than the benchtop (which I was prepared to be ok with). But when I screwed it down to the shelf, the rubber feet compressed, and I was able to use that screwdown to get it pretty much exactly flush.  I'm thinking there is at least 2mm of play in the compression of those rubber feet - I'm not sure if Festool did that on purpose, but it worked out really well for me.
Offline Doug S
« Reply #5 on: April 10, 2021, 05:40 PM »
As I understand the whole "system" thing went a bit wrong when TLOCS came out. The KS120 base is the same height as a CLASSIC sys1 but not a TLOC sys1. Despite classics and tlocs having the same stack height the tlocs are actually higher because of their feet.
To confuse things even further I think the base of the KS60 is the height of a TLOC sys1  [blink]
Not sure if that answers your question.
