Author Topic: How set the TS55 0/45 bevel index (to zero)?  (Read 1123 times)
Offline threesixright
« on: September 06, 2018, 03:32 PM »
Sorry, this is crosspost :-[ I asked yesterday same question (general section), but didn't get a lot of response. I hope you don't mind asking here (again). Otherwise please remove this post.
As you can see on the picture the indicator for the angle sits just below 0. Saw is brand new (not used). I did read the manual and they state the FT after service could adjust it.
Is it just a matter of turning the screw (picture, yellow circle)?Or is there more to it?
Thanks!
Offline Gregor
Re: How set the TS55 0/45 bevel index (to zero)?
« Reply #1 on: September 07, 2018, 02:47 AM »
The screw actually adjusts the blade angle at 0°. To only adjust the indicator you'll need the screw in the top of the picture.
Offline Joe Felchlin
  • Just another day in paradise - Livin’ the dream!
« Reply #2 on: September 07, 2018, 06:45 AM »
If you can make the adjustment simply - Great.
I bought a Recon TS 55 that was supposed to be “reconditioned” - And wasn’t.
The base plate COULD NOT be registered to 90 or 45 degrees with the blade -
Even though the indicator showed it was.
I sent it back to Festool. They fixed the problem.
Something to check/consider.
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
Offline Peter Halle
« Reply #3 on: September 07, 2018, 07:28 AM »
In case Festool misses this thread I would suggest that you call them at the 888 337-8600 phone number and talk to service.  They are helpful and having them on the phone can be helpful.
