Author Topic: hose length  (Read 3371 times)
Offline adrian130980
hose length
« on: September 04, 2014, 05:36 AM »
Hi
I have a festool ctl 26 and would like to know what is the maximum or recommended max length of 50mm hose?
Many Thanks
Adrian
Hi my names adrian and I'm a......Festool addict.
Currently own...kapex 120, ts55, domino xl, rotex 125, parallel guides and extensions, rs 300 and 1400 router.
Home made mft table, ron paulk design.
Offline jonny round boy
Re: hose length
« Reply #1 on: September 04, 2014, 06:21 AM »
Adrian,
That would depend on what you are connecting it to...
TS55R EBQ saw - CTL26 - CTL Mini - OF1400EBQ router - KS120 Kapex SCMS - ETS150/3 sander - RO90 sander - DF500 Domino - PDC18/4 drill - PSC420 jigsaw - OFK500 trimmer
Re: hose length
« Reply #2 on: September 04, 2014, 06:22 AM »
Hi
It would be to a kapex 120 or ts55
Adrian
Online Peter Halle
Re: hose length
« Reply #3 on: September 04, 2014, 06:29 AM »
Here is a thread where you might find some useful information although it doesn't exactly address your situation.  It is older (prior to the 26 and 36) but their suction is a little bit greater.
http://festoolownersgroup.com/ask-festool/max-length-of-50-mm-hose-without-loss-of-suction-efficiency/msg187453/
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
Re: hose length
« Reply #4 on: September 04, 2014, 10:18 AM »
Adrian,
Here's a document (attached below) that will give you guidance on maximum hose length and how to make the connections between hoses.
Shane
Re: hose length
« Reply #5 on: September 04, 2014, 12:07 PM »
Hi
Adrian
You don't need the 50mm hose for either of those, the 36mm would be sufficient. The best solution for the Kapex is a 1.75m length of 36mm hose (buy a 3.5m & 2 extra fittings, make 2 hoses, sell the extra one), but that would be no good for the TS55!!! Works great as a dedicated hose for the Kapex though.
If you want to use the same hose for both, then go for the 3.5m 36mm (unless you have a specific reason to want to go longer?).
Re: hose length
« Reply #6 on: September 18, 2014, 08:02 AM »
Hi
sorry i put 50mm by accident, i meant 36mm
i am attaching a kapex 120 and also separately a mix of ts55, domino xl & ts55
Thanks for all the advice
adrian
