Author Topic: ETS 125 EQ Issue  (Read 3354 times)
Offline dzink
ETS 125 EQ Issue
« on: May 09, 2010, 08:09 PM »
I can no longer get a peice of sandpaper to adhere to the bottom of the tool. It seems that the black plastic pad with the micro"hooks" is worn out. I keep it clean, but you can no longer get sandpaper to stay on the tool when running at any speed. The tool is only 5 months old but gets almost daily use. Can I order a repalcement pad and install it myself?  I'm thinking it might be a good idea to have a backup pad handy.
Offline Bob Marino
Re: ETS 125 EQ Issue
« Reply #1 on: May 09, 2010, 08:16 PM »
 Yes, pads are available. You'd probably want the same pad as came with the ETS - item # 492-280.
 Bob
« Last Edit: May 09, 2010, 08:23 PM by Bob Marino »
Former Festool  Dealer since 2002; user well before that!
Offline Brice Burrell
« Reply #2 on: May 09, 2010, 08:20 PM »
(Bob beat me to to the punch). Yes, you can order a new pad from any Festool dealer for $29.50 USD. The pads are very easy to change. The part numbers are:
Soft pad, the pad that comes on the sander: 492280
Super soft pad: 492282
Offline honeydokreg
    • honeydokreg@aol.com     email address
« Reply #3 on: May 09, 2010, 09:03 PM »
yep they wear out with use.  and if you use it daily then a back up might be good... thats the thing in what I do and others, is having to have 2 and 3 of things for back ups, and because it sounded good at the time to have a back up !
just like routers  you need one router for every bit you have plus one more in case you buy a bit on the whim !     [laughing]
and if you are in the middle of sanding and it has worn out then a back up is necessary !
pay attention to the details.... they make the difference... festool does
www.builtinking.com
youtube channel:  builtinsbykreg
Offline harry_
« Reply #4 on: May 09, 2010, 10:02 PM »
Kreg,
you are out of control!
Offline Alex
« Reply #5 on: May 10, 2010, 03:23 AM »
That's normal with any type of sander from any brand. Replacing the pad after 5-6 months is about average with daily use. You can replace the pad yourself and is very easy, you just have to drive 4 screws.
Offline dzink
« Reply #6 on: May 11, 2010, 05:47 PM »
Thanks guys. I went by the dealer today and picke dup the replacement part.
