Hi. That is good to hear it worked well. I discovered them after reading the list created by Seth on aftermarket items for Festool.
I have a similar setup. My mft does not move, and I have a homemade boomarm (central vac pipe and fittings) mounted on the wall behind my table that swivels. I have the same issue with the whip as you, no matter what I do, the extra loop that is tied back when not using the whip seems to get caught on something....lol
I only had one Festool sander up til Saturday (Ro90) and using it with the 36mm hose seemed fine to me....I will have to see how my new sanders (ets 125, dts 400 and rs2e) are like to use with the larger hose...not sure how well the smaller ones will like the bigger hose....oh well it's great to have options!!
I've thought about just making an extension for the plug it cord perhaps a little longer than the 18 inch hose whip but not sure if the plug it parts are available as I'd need both ends.....
If the parts were available I think I would add that to my options.....anybody know if you can buy theses parts in Canada?
grbmds:
I also have the non anti static hoses as well....use them with my shop vac and Dust Deputy in the larger area of my shop where I cut up plywood. I do find a bit of static at times when using my ts55, but it also seems to be dependent on humidity at the time....I have electric heat in my shop so it can get pretty dry at times.
I didn't have a extractor when I first started using my saw, so didn't see the point of buying the anti static hose at the time...I have a extractor coming now, and like you have opted for the larger hose....good luck, you'll get it all solved and the people here are of great help....
Greg.
