Author Topic: ekat image # v. Part #?  (Read 3213 times)
Offline Northern Early
« on: July 10, 2014, 11:38 PM »
My PSB 300 needs a part, it is under warranty but to reduce downtime i figure i would just buy the part. So i went on eKat for my first time. After about 30 min of figuring out how to make java enable i have a picture of the part and a list of part numbers and prices. I would figure if i hovered over a part in the picture that a P/N would appear.
Basically, how do i transfer square 39 from the parts image to a part number in the parts list?
P.S. i understand why festool can't/won't, but it would be super neato to be able to get warranty parts sent instead of tool transfer back and forth. My PSB works, just not well, but i can't really go more than a couple days without it. Makes me wish i didn't give a friend my bosch when i bought the festool.
Offline Alex
Re: ekat image # v. Part #?
« Reply #1 on: July 11, 2014, 05:31 AM »
Normally, if you click a number on the picture it highlights red and a box with the details comes up. The list beneath the picture also focusses on the part number you clicked.
I say "normally", because very often the ekat doesn't work as intended, it is very buggy for some reason.
For instance, I can't illustrate my post with a screenshot right now, because the entire ekat is out.
Edit: seems it's working again.
109594-0
« Last Edit: July 12, 2014, 03:59 AM by Alex »
Offline wow
  • Inactive Member
« Reply #2 on: July 11, 2014, 06:20 AM »
Here ya go - apologies for the formatting:
Note: Prices are in US Dollars
Position | Part No.| Description | Quantity | Price excl VAT | Price incl VAT
   1    491852    Armature 110-120V    1    46.51
   2    491853    Field assembly 110-120V    1    25.10
   3    486317    Switch attachment    1    10.31
   4    489622    Socket housing 120V    1    5.59
   4    491904    Socket housing GB  110V    1    7.38
   5    492158    plug it-cable CN  230V    1
   5    496087    plug it-cable JP    1
   5    490650    plug it-cable GB  240V    1
   5    490649    plug it-cable CAN    1
   6    400669    Raised-head screw 3,5 x 30 mm    7    0.78
   7    451796    Stripper    1    2.55
   8    451371    Bush    1    2.05
   9    490207    Gearbox cover    1    45.84
   10    228509    Raised-head screw M4 x 12    3    0.78
   11    451372    Bush    1    3.51
   12    451366    Bending spring    1    0.78
   13    451367    Clamping lever    1    4.11
   14    400565    Raised-head screw 3,5 x 70 mm    2    0.78
   15    457337    Flange bolt    1    1.47
   16    490209    Connecting member    1    12.35
   17    490210    Lifter rod    1    46.98
   18    461987    Wrench    1    6.68
   19    228520    Nut; M5    1    0.78
   20    458983    Slide    1    10.34
   21    490120    Splinter guard    1
   22    453082    Washer    1    1.43
   23    490212    Slide inlay    1    9.23
   24    400062    Screw; M4x7    6    0.78
   25    400526    Screw; M5x25    1    0.78
   26    489687    Bracket    1    18.06
   27    400535    Cheese head screw M4 x 20    2    0.78
   28    400008    Needle sleeve    2    2.98
   29    490213    Cam    1    20.96
   30    451356    Weight    1    18.12
   31    490214    Gear    1    18.23
   32    490208    Gear housing    1    43.98
   33    490215    Gasket    1    8.74
   34    455186    Bearing    1    13.77
   35    200617    Circlip; A 8x0,8; DIN 471    1    0.78
   36    400009    Supporting ring    1    0.78
   37    457043    Washer    1    0.78
   38    490216    Pendulum drive    1    10.70
   39    490217    Holder    1    13.62
    40    490218    Pendulum control lever    1    10.96
   41    219031    Raised-head screw 3,5 x 10 mm    2    0.78
   42    491571    Hard metal holder    1    28.30
   43    400678    Cheese head screw M3 x 8    1    1.21
   44    453491    Cover    1
   45    700077    Absaugstutzen    1    5.29
   46    400626    Ball bearing    1    4.91
   47    457383    Fan    1    2.05
   48    228672    Ball bearing    1    3.50
   49    444018    Solenoid ring    1    0.85
   50    461985    Air guide washer    1    1.48
   51    219069    Raised-head screw 3,0 x 12 mm    2    0.78
   52    400524    Raised-head screw 3,5 x 30 mm    2    0.78
   53    449640    Motor housing    1    8.93
   54    491157    Brush holder with brushes (pair) 100-240V    1    13.73
   55    491698    Electronic 110V    1    56.71
   55    490222    Electronic 120V    1    56.71
   56    451354    Gasket    1    2.46
   57    493553    Brush (pair) 110-120V    1    13.73
   58    494166    Base    1    15.76
« Reply #3 on: July 12, 2014, 01:02 AM »
Thanks Alex. That's exactly what i figured would happen if everything was working. Click an item and get a popup list of information. Apparently i should look into software updates. you only need to do that every 4 years right :) I don't get green circles around numbers to click on. Also i am on a mac. in college allot of things didn't transfer over but java is pretty universal.
Thanks WOW, a perfect list for what i need. This will help me get the part while i figure out the kinks in my system.
« Reply #4 on: July 14, 2014, 02:10 AM »
I just went searching for a part for my midi and the system (ekat) worked as i figured it should. Just as Alex said it does. So i went back to the PSB and it as well works as it should. I don't think i changed something, maybe ekat did. i don't know but i do know it works  [big grin] [big grin]
