Author Topic: Domino cutter size guide.  (Read 2930 times)
Offline P_Bennett
« on: May 02, 2021, 07:00 AM »
Morning one and all,
I’m looking to purchase a domino machine!
but after looking about I was trying to find some information regarding the recommended domino size for the intended application.
I see on the Festool site they state the machines intended use, but is there a rule of thumb or guide that lets you know what thickness or length of domino to use depending on the material type or application?
Im new to the world of woodworking so be gentle
Regards
Paul
Offline Thompmd
Re: Domino cutter size guide.
« Reply #1 on: May 02, 2021, 07:25 AM »
Great Idea, I’ve not seen one and I hope someone has one they can post.
Sawstop Industrial Saw, TS75,2 800,2 1400 & 2700 rails, CT36, Rotex RO 150 FEQ, CT-VA-20, Carvex PS 420 EBQ, Carvex acc. ZH-SYS-PS 400, Kapex KS 120, CT Cyclone Dust Collection Pre-Separator CT VA 20, DF 500 Q Set, Domino 1,060pc Tenon Assortment, UG-KA-SET Portable Imperial Stand & Extensions,OF1400 EQ-F-Plus, MFT/3, MFT-SP, FS-HZ 160, TSC 55, T18 E
Offline Sparktrician
« Reply #2 on: May 02, 2021, 08:13 AM »
The general guidance regarding thickness of dominoes is 1/3 of the thickness of the materials being joined.  For example, 3/4" (18-19 mm) material would get 6 mm dominoes centered in the material.  Length is what you need it to be to get the best/strongest joint without blowout, if close to the edge of the material.   [smile]
- Willy -
Offline P_Bennett
« Reply #3 on: May 02, 2021, 08:19 AM »
Awesome thank you, very much appreciated.
Regards
Paul
Offline tsmi243
« Reply #4 on: May 02, 2021, 09:56 AM »
Basically the 1/3 rule.  Once you have them in hand, it'll be pretty obvious just by looking which one you want to use.
In plywood, I've started dropping down one size, as I read here somewhere.  It works well.  If you cut a 6mm hole in 18mm stock, the material left around that hole isn't super strong.  And a 6mm domino is probably stronger than you really need.  So try a 5mm and see if you prefer that.  Either one will work.
If you're like me, and only really use 2 or 3 material sizes, you'll just remember that 3/4" gets the 5's, and 6/4" gets the 10's.  Something in between would get something in between.  It's pretty easy.
Offline P_Bennett
« Reply #5 on: May 02, 2021, 11:46 AM »
Great
Thank you for the help!
Regards
Paul
Offline ChuckS
« Reply #6 on: May 02, 2021, 11:57 AM »
Snip.
Your machine will come with a manual that includes, among other things, the guidelines on domino thickness (reproduced here). The wood you use may affect your choice.
Of course, guidelines can be ignored if you can justify it. One study did find that the joint strength (in hardwood) was much stronger using the 1/3 thickness tenons than 1/2 thickness ones.
I deal with mostly hardwood, and use 8mm dominoes for 3/4" materials by default in wide pieces. For much thicker stock, I go with double tenons (8mm or 10mm, subject to the 1/3 rule).
« Last Edit: May 02, 2021, 12:16 PM by ChuckM »
Offline clark_fork
« Reply #7 on: May 02, 2021, 12:06 PM »
This is what helped me when I got started:
Clark Fork
"A lot of people are afraid of heights. Not me, I'm afraid of widths."  Stephen Wright
"straight, smooth and square" Mr. Russell, first day high school shop class-1954
" What's the good of it?" My Sainted Grandmother
"You can't be too rich, too thin or have too many clamps." After my introduction to pocket joinery and now the MFT work process
"Don't make something unless it is both made necessary and useful; but if it is both necessary and useful,
don't hesitate to make it beautiful." -- Shaker dictum
Offline P_Bennett
« Reply #8 on: May 02, 2021, 12:17 PM »
(Attachment Link)
Thank you for the guide and the images
This will be a great help!
Thank you all gents for your help
Regards
Paul
Offline Birdhunter
« Reply #9 on: May 02, 2021, 03:20 PM »
Halfinchshy and New Brit Workshop both have great videos on using the Domino machines. Watch those, read the Supplemental Manual, and practice on scrap before using on valuable wood.
Birdhunter
Offline P_Bennett
« Reply #10 on: May 02, 2021, 03:41 PM »
Awesome thank you fella
Regards
Paul
« Reply #11 on: May 02, 2021, 05:19 PM »
Here's some general Festool recommendations.
Offline P_Bennett
« Reply #12 on: May 03, 2021, 03:34 AM »
(Attachment Link)
(Attachment Link)
Hi
This is awesome!
Thank you one and all for your help and advice
Regards
Paul
Offline rst
« Reply #13 on: May 03, 2021, 09:37 AM »
As rule I stick to the 1/3 quideline, that being said...I have a small house that we have added onto. A 24 x 36 original bungalow that my wife's off the boat Polish grandparents built in the early 1920s.  All my selfmade trim is quater sawn red oak.  I've been using 6mm dominoes with no issues.  Join my baseboard with 45s and dominoes and also the 45s on my wndow trim.
Offline Bert Vanderveen
« Reply #14 on: May 03, 2021, 11:25 AM »
The
Domino_DF_500 supplemental manual
is a good source for the information you seek.
Also: if you use dominoes with plywood you should aim to keep at least one full ply down and under untouched.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline P_Bennett
« Reply #15 on: May 03, 2021, 12:55 PM »
Hi
Great thank you
Offline P_Bennett
« Reply #16 on: May 03, 2021, 12:56 PM »
The
Think I shall Download it now
Regards
Paul
