I have got a different question about the new midi 2.
Can the new midi 2 be used without a bag fitted just relying on the main filter to capture dust and debris?
Can any body help?
Cheers John
I wouldn’t do it, unless:
You are sure you’re only, and only using it for course grain say ie from a planer or other “clean” large particles.
So in short, no. The filter will clog. That’s the purpose of using a bag, the bag is pre-filtering before the main and protective filter.
For water pick up, as CeeJay says, there is a special filter for that. And of course no bag in this instance.
I’ve walked away from three possible buys of pre-owned CT26/36 because I noticed they had been used without a bag. With steep used prices on Festool, even on the dust collectors which most have seen heavy use, adding broken parts, new filter, new hose, new connectors - the price of a new dust collector seems often the Best Buy. Cause, you never know when a used one fails on its most expensive part - the motor or bearings.
So if you’d like to keep its value and longevity in faultless performance, use a bag
![Big Grin [big grin]](https://www.festoolownersgroup.com/Smileys/default/biggrin.gif)
