Author Topic: CT36 Plug Tap Rating  (Read 18111 times)
Re: CT36 Plug Tap Rating
« Reply #30 on: December 21, 2010, 03:36 PM »
Power tools have labels indicating how much current they draw but I'm not sure
under what conditions the current is measured. Is the tool idling or working hard at full power?
The vac may draw a certain number of watts when sucking dust off the floor
but when you put your hand over the end of the hose to judge how clogged
the filter bag may be it starts working hard and using a lot more watts.
Which of those conditions is closest to the condition the amperage rating refers to?
We all know simple electric motors take a big gulp of power when they first start up
but the current draw settles down as the reach there no load maximum speed.
Slow start motors don't do that.
Festool's previous generation of CTs waits a sec or two before it starts pulling power
when it is prompted by a tool start. My older Fein Turbo vac starts up simultaneously with the tool.
I think this limits the number of watts the power tool can consume compared to the Festool vacs.
Do the new CTs start quicker so they can't pass through as much power as before or
are the UL guys being more picky than before?
Anyway, the bottom line is still common sense. If the vac's power cord is getting hot
let the tools rest while you find a way to either reduce the resistance (shorter extension cord)
or run the tool on a power supply other than the utility outlet on the vac.
If the power cord doesn't get hot you've nothing to worry about, assuming there isn't some
hidden power choke point inside the vac. that wasn't in the previous generation.
Offline Alex
« Reply #31 on: December 21, 2010, 05:40 PM »
**  Nobody from Europe has told us what the max amperage draw is on their CT that runs on approx. 230vac.  **
That's because we never use amps in relation to power tools like Americans do. We always use watts over here.
That's why I was curious as to why no one from Europe or other areas that run on 230vac letting us know what their CT's warning label states
That's because we don't have any warning labels on our power tools like Americans have. We always just use them until they explode.  [embarassed]
Anyway, I don't know what the limit is on the CT's. I know I have used my 2200 watts CS70 on the CTL Mini, the CTL 22 and the CTL 26 without problems.
Offline Ken Nagrod
« Reply #32 on: December 21, 2010, 05:44 PM »
THANK YOU
Offline jmbfestool
« Reply #33 on: December 21, 2010, 05:46 PM »
+1 What Alex said!
I got a personal message from Ken Nagrod asking what the Amps was on it  its on the warning sticker!  I couldnt remember a warning sticker so I just had a look and nope their aint one!  We in europe dont care about that stuff! lol Like alex said bang a plug in and see what happens! Hey we run 240V! You Americans run 115! We clearly dont care we just want more power! Untill health and saftey steps in and makes usgo down to 110V I dont kno why England does not just run 110V such awaist of energy converting all the time with these little transformers on site.
JMB
*********************************************************************** [thumbs up]UK members click me
Offline jmbfestool
« Reply #34 on: December 21, 2010, 05:47 PM »
Oh I see Ken!  You say Thank you to Alex and not me!   I told you der was no sticker!!!!  Instead you tried to make me take my CT apart and have alook inside ! [tongue]
JMB
Offline Ken Nagrod
« Reply #35 on: December 21, 2010, 05:53 PM »
Thanks JMB.  I'll help you put it back together  [huh].
Offline ADKMedic
« Reply #36 on: December 21, 2010, 08:35 PM »
This may be a silly question, but if the tool and vac combination were drawing too much power off of a 15Amp circuit, wouldn't/shouldn't the circuit breaker trip way before there was a fire risk???
Andy
T-15+, RO150, TS55, CT-36, Pro5, DTS400, OF1400, OF1010, PS-420-EBQ, MFK700, DF-500, VAC-SYS, MFT/3 x2, CMS-GE, LR-32, soon a KS-120REB on a date sometime between now and eternity!
Offline Ken Nagrod
« Reply #37 on: December 21, 2010, 08:51 PM »
Andy,
There are usually  a lot of safetys in place.  Most of the time those work perfectly.  There's always the chance something could go wrong since every location is different and not every factor is forseeable.  Wow, I should have been a lawyer!  Get my point?  Play it smart by making sure your safetys work like the breaker and like previously stated, use common sense.  Definitely don't continue if you feel the cords are hot, smell smoke, the tools slow down, etc.  The Festools have protection as well.  And try not to be a worry wart about it.  Otherwise you'll never get anything done.
« Last Edit: December 21, 2010, 08:57 PM by Ken Nagrod »
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« Reply #38 on: December 21, 2010, 11:53 PM »
There is a very good reason why Festool is silent in this discussion, and that is because if they made any comment beyond what is printed on the sticker, they would lose the UL listing for the vac.
The reason for the amperage limitation sticker on the vac is directly related to the UL requirement for vacuums with external power receptacles, coupled with the absence of the NEMA 5-15 to 5-20 adapter tail that was previously available. These conditions mathematically mandate the value shown on the sticker. I won't publicly contradict this mathematical value for the same reason Festool won't. However, someone asked about the internal wiring of the vac and what it could withstand. The simple answer is that the internal wiring of the vac can withstand the full amperage of the circuit without sustaining damage.
Offline Jeff Zanin
« Reply #39 on: December 22, 2010, 07:02 AM »
Interesting comments from Rick regarding the UL considerations.  Now I get why there will never be an official response.
<off topic rant>
This not the first time we have seen unusual outcomes regarding availability, specification, documentation and other non-operational aspects of equipment from UL.  My favorite Festool example of this is the vac sys.
It is hard for me to understand or believe that tools and equipment that not only meet CE requirements but are in regular use in Europe and other parts of the world somehow become unsafe, unsuitable or unsatisfactory when they are "evaluated" by UL for use in North America.  The only explanation I can think of is that the U.S. is a more litigious society and that the UL requirements and process are an attempt to minimize exposure to lawsuits.
I appreciate the concept but I find UL approval less than credible when I look at some of the unbelievably cheap, poorly made, flimsy, flakey, etc. items (many from Asia) that somehow achieve UL approval.  To me this indicates some issues with competence and / or integrity in the process.
</off topic rant>
For the CT36 I can see there may be a different power rating in NA compared to Europe due to voltage differences and "the UL requirement for vacuums with external power receptacles" (ref. UL 1017 4.4.1.4 [ISBN 1-55989-191-2] – it is available online but is copyrighted so I will not provide the link here).
Jeff
