Author Topic: CT36 Plug Tap Rating  (Read 18450 times)
Offline ultgar
    • Ultimate Garage
« on: December 20, 2010, 05:25 PM »
Received my CT36 today and was surprised to see a sticker on the plug tap cover suggesting not to exceed 3.1a (approx 375w) with any power tool plugged into this receptacle.  This obviously has to be a mistake with the sticker as the CT33 had a 1200w sticker.  Did anyone else notice this problem?
see http://www.ultimategarage.com/festool/ct36powerrating.jpg
Offline Tom Bellemare
  • Inactive Member
Re: CT36 Plug Tap Rating
« Reply #1 on: December 20, 2010, 06:04 PM »
That's what mine says.
Offline ultgar
    • Ultimate Garage
« Reply #2 on: December 20, 2010, 08:06 PM »
I mention it because I get calls all the time with the Alto vacs I sell....customers want to know if they can safely plug their Saw or Router into the vac for tool triggered auto-start.  I switched several customers last year from Alto to Festool because of this requirement....Alto vacs have a 600w recommended max on the receptacle cover.
According to the CT36 sticker (not sure about the CT26 but I assume its the same) which was presumably on the machine for UL approval, customers should not plug anything drawing greater than 3.1 amps (370w max ) or there might be a risk of fire.  I am still waiting for someone from Festool to get back to me on this.  Steve D
Offline wnagle
« Reply #3 on: December 20, 2010, 08:42 PM »
Not sure what it means but It doesn't say 3.1  It says 3,1.  I'm not sure why the comma instead of a decimal point, but it may be a clue to the mystery.
Wayne
TS 55, CT 33 x2, ROTEX 150, RO 90, DOMINO 500Q SET, TRION PS 300, OF 1400, MFT/3, ETS 150/3, KAPEX KS 120, DOMINO XL.
  • Inactive Member
« Reply #4 on: December 20, 2010, 08:43 PM »
Europeans use a comma instead of a period.
Offline wnagle
« Reply #5 on: December 20, 2010, 09:08 PM »
ahhh, I don't get out much!
Wayne
Offline JD2720
« Reply #6 on: December 20, 2010, 09:13 PM »
Well, I used my CT36 for 3 days last week with a Kapex connected to it & nothing caught on fire.
Offline Brice Burrell
« Reply #7 on: December 20, 2010, 10:23 PM »
I've used my 26 with the OF2200 and I've made miles of cut with the TS55.
Offline tDot
« Reply #8 on: December 21, 2010, 02:17 AM »
I'm going out on a limb here, as I don't know all the CT 36 specs, but doesn't the CT36 only come with the plug for a 15A outlet?  Does it even include the 20amp outlet adapter like the CT33?
Either way, the sticker probably has something to do with the Max amperage draw that would be allowed on a 15Amp outlet, if the vac was at full power. I'd assume max amperage draw would be approx 12Amps for the vac. So you would only have a small balance of available power remaining.
Offline Festoolfootstool
  • The trouble with Bob is its all about Bob
« Reply #9 on: December 21, 2010, 03:17 AM »
I  was told by Festool UK that using the of2200 with the ct26 36 was fine and would not cause any problems or warrantee issues
If the milk turns out to be sour, I ain't the kind of **** to drink it.......
Why do Festool accessories only have a two month guarantee here in the UK ?
Offline Jeff Zanin
« Reply #10 on: December 21, 2010, 06:34 AM »
Interesting - what is the mains voltage in the UK?
In the U.S. and Canada it is 120VAC, I am wondering if the power available here is reduced compared to someplace where the voltage is higher.
I don't see an electrical specification for the CT36 on the Festool USA website, but if the vac is intended for use on a typical 15A branch circuit there might not be much amperage left to power a tool when the vac is running at full power.  What type of plug does the CT36 have – 15A or 20A?
I have used my CT22 on a 15A circuit with the TS-75 (and with a Bosch 4100  [scared]) with no issues, but the run time of the tool + vac is typically quite short and likely not enough to pop the breaker, and there was nothing else in use on the circuit.  But whenever possible I remove the pigtail and use a 20A receptacle and circuit.
Jeff
« Reply #11 on: December 21, 2010, 07:25 AM »
Hi The voltage I was talking to festool about was 110v 50 cycles which is used on uk construction sites
Jeff
Offline fdengel
« Reply #12 on: December 21, 2010, 07:40 AM »
The PDF of the user's manual from the festoolusa site indicates that the connected power tool should not exceed 3.7 amps, or 9.1 amps at minimum suction, for the CT 36.
This seems strange to me, I thought my CT 22 allowed more than this?
« Reply #13 on: December 21, 2010, 08:48 AM »
Forget what the literature says.  The vacs are meant to be used with any of the tools we have here in N America.  Festool wouldn't sell the tools and vacs packaged together if they didn't intend for you to use them.....
Offline ultgar
    • Ultimate Garage
« Reply #14 on: December 21, 2010, 08:55 AM »
I agree.  I sell a lot of Alto vacs and their engineers have indicated to me that the sticker on the Alto machines (600w max, 500w max with XC models) was there to satisfy UL requirements.  The CT36 now comes with a 5-15P plug eliminating the hassle (and cost) of the plugtail adapter.  Despite the hefty 12 gauge cord, the CT can now be plugged into any 15 amp convenience outlet .  Tool triggered autostart is a great feature/convenience but the use of higher amperage tools (saws, routers, etc) through the AS circuitry will compromise the performance and longevity of both the vacuum and tool.  Throw in a 50' or 100' 14 gauge extension cord that most contractors use and you really have a problem.
I received an official response from Festool this morning and it appears they are upset with me for discussing it on this forum.  I was trying to tap into the strong presence of Festool dealers who frequent here.  SD
Offline Ken Nagrod
« Reply #15 on: December 21, 2010, 10:06 AM »
Steve,
So I guess now there's a gag order placed on you?  Maybe you should have done it on the Wikileaks site?
I just checked my CT36.  At 3.1 amps it's fine.  At 3.2 amps it starts melting the top of the vac.  At 3.3 amps a fire started and the whole thing went up in flames.  Now I need a new vac.  Maybe I'll try the Alto.
« Last Edit: December 21, 2010, 10:14 AM by Ken Nagrod »
Offline Gone
« Reply #16 on: December 21, 2010, 10:18 AM »
The bottom line is Festool has outlined their specifications to satisfy UL and they or their dealers have the responsibility to follow. What you do with the equipment after purchase is your responsibility and will only come under scrutiny when there is a problem with warranty or problem with the equipment damaging personal property. Whether you can hook up and run an OF2200/CT36 at full load isn't really Festool's concern because they have covered themselves by load statements in the owners manual.
John
Offline Jeff Zanin
« Reply #17 on: December 21, 2010, 10:35 AM »
<snip>
I can see why they would be concerned but at the same time there is a broad range of Festool experience and expertise among FOG members, and the opinions range from:
<snip>
to:
John
both of which sound reasonable to me, but which are a bit contradictory.
So for those that have or are considering one of the new vacs an official response or clarification would be a good thing.
Jeff
Offline ultgar
    • Ultimate Garage
« Reply #18 on: December 21, 2010, 11:18 AM »
Festool is issuing an official position to its dealers which is understandably vague and protects them from liability.  It is up to the dealers to interpret/explain this position to their customers. My interpretation as a dealer (Ultimate Garage)  would be as follows...........
CT Dust Extractors are engineered to work with ALL Festool power tools assuming the CT is plugged directly into a dedicated 20amp (115-125v, 60hz) circuit without the use of cord extensions. However, there may be compatability issues with non-Festool products (without MMC electronic thermal & overload protection) used in conjunction with the Festool CT vacuums. To ensure maximum performance of ANY power tool used with the CT Extractor, separate circuits should be used for each device. The CT should never be used with a compromised power supply (ie, line voltage less than 110v or greater than 130v).
Steve D'Gerolamo
Offline Jeff Zanin
« Reply #19 on: December 21, 2010, 12:53 PM »
Steve D'Gerolamo
That seems quite reasonable and incorporates the common sense aspects of Brice's comments with an appropriate scope limitation.
I'll have to break the news to Mr. Bosch 4100 that he can no longer use the magic receptacle on the CT...  ;D
Jeff
Offline Chris Wong
  • Festool Dealer
  • I make things that challenge me.
    • Flair Woodworks
« Reply #20 on: December 21, 2010, 01:17 PM »
Steve,
Thanks for getting to the bottom of this for us.  I had the same concern.
Chris Wong, http://FlairWoodworks.com and https://www.ultimatetools.ca/
First Festool was a free pencil.
Shipping live-edge cribbage boards around the world since 2010.
« Reply #21 on: December 21, 2010, 01:29 PM »
That seems quite reasonable and incorporates the common sense aspects of Brice's comments with an appropriate scope limitation.....
The two words in bold are key here.  I mean if Festool vacs could only be used with their smaller sanders don't you think Festool would make that very clear.  Besides, how many posts have you read here about CT extractors bursting into flames...none (well, actually, only one, but that was the dust in the bag, not the extractor itself).
Offline Pete Pedisich
« Reply #22 on: December 21, 2010, 02:02 PM »
I have used my CT22 with the OF1400, TS55, Bosch 13amp circular saw, DW 618 Router on a 15amp circuit, never a problem. I never use an extension cord with my CT22 or my 6 gallon compressor, but tradesmen have no choice often.
Anyone know if the 120 vs 240v issue gives us (in the US/Canada) less real world capacity in the tool receptacle on the CT's?
Offline Alex
« Reply #23 on: December 21, 2010, 02:05 PM »
Guys, just get a 230 volts net, all problems solved.  [tongue]
Offline Ken Nagrod
« Reply #24 on: December 21, 2010, 02:28 PM »
Quote
The basic formula is E=IR.  E the voltage, I the current and R the resistance.  Doubling the voltage, halves the current while the internal resistance of the CT remains constant, so makes no difference for current draw of the attached tool.
**  Nobody from Europe has told us what the max amperage draw is on their CT that runs on approx. 230vac.  **
...or forget about using the CT altogether and call Merry Maids when your done.
« Last Edit: December 21, 2010, 02:36 PM by Ken Nagrod »
  • Inactive Member
« Reply #25 on: December 21, 2010, 02:42 PM »
Quote
Yes, unless the wiring between the receptacle and the main power bus in the tool was increased for the NA versions.
If these are wired for (and this is just an example) 2300 watts and 230 volts, that would be 10 amps. If I lower the voltage to 115 volts, the same wiring can still only carry 10 amps, so the power capacity is 1150 watts.
I don't know exactly how they were wired, but I use the example above strictly for demonstrative comparison.
The voltage a conductor can handle is dependent on the insulation and most common wiring I've seen can take 600 volts very safely. The current carrying capacity (sometimes called ampacity) is dependent on the conductor (size, configuration, material, and surrounding). So the wire will limit the current but the insulation won't limit the voltage in this case because the voltage is dropping. If the voltage drops and the current remains the same, the power drops proportionately. 1 watt = 1 volt * 1 amp
I see you posted while I was writing this, Ken. I may be wrong but I don't think the wiring's resistance is significant in this analysis.
Offline Ken Nagrod
« Reply #26 on: December 21, 2010, 02:52 PM »
That's why I was curious as to why no one from Europe or other areas that run on 230vac letting us know what their CT's warning label states and with the CT, it's not just about the external wiring you see but also the internals receiving the full ac power before any step down and rectification.
Also, if anyone is just dying to do the math, when talking about power and alternating current, watts = volts x amps x 1.414  (sine wave).  When dealing with straight direct current it's only w=va.  Sorry for the nerd lesson.
« Last Edit: December 21, 2010, 03:01 PM by Ken Nagrod »
  • Inactive Member
« Reply #27 on: December 21, 2010, 03:00 PM »
I hate to make assumptions, but sometimes it helps reason things through... In this case, I'm assuming the receptacle wires directly to the power cord termination, which would mean that wire is the determining factor. Maybe they upgraded it for our lower voltage. That's what I would do.
Offline Ken Nagrod
« Reply #28 on: December 21, 2010, 03:06 PM »
Tom,
In the interest of, well, probably no one, would you be willing to take apart one of your display model CT's so we have an answer.  [tongue] [big grin]
I'm sure like everyone else here, we'll just keep doing what we've been doing and if something trips and if we're smart, we'll change the way we do it.  Happy vacuuming!
« Reply #29 on: December 21, 2010, 03:13 PM »
WOW, that stuff is way over my head.
I don't understand electrical, but I do know my CT22 has worked as designed for me for 4 years without an issue! ...maybe I should stop thinking. [big grin]
« Reply #30 on: December 21, 2010, 03:36 PM »
Power tools have labels indicating how much current they draw but I'm not sure
under what conditions the current is measured. Is the tool idling or working hard at full power?
The vac may draw a certain number of watts when sucking dust off the floor
but when you put your hand over the end of the hose to judge how clogged
the filter bag may be it starts working hard and using a lot more watts.
Which of those conditions is closest to the condition the amperage rating refers to?
We all know simple electric motors take a big gulp of power when they first start up
but the current draw settles down as the reach there no load maximum speed.
Slow start motors don't do that.
Festool's previous generation of CTs waits a sec or two before it starts pulling power
when it is prompted by a tool start. My older Fein Turbo vac starts up simultaneously with the tool.
I think this limits the number of watts the power tool can consume compared to the Festool vacs.
Do the new CTs start quicker so they can't pass through as much power as before or
are the UL guys being more picky than before?
Anyway, the bottom line is still common sense. If the vac's power cord is getting hot
let the tools rest while you find a way to either reduce the resistance (shorter extension cord)
or run the tool on a power supply other than the utility outlet on the vac.
If the power cord doesn't get hot you've nothing to worry about, assuming there isn't some
hidden power choke point inside the vac. that wasn't in the previous generation.
Offline Alex
« Reply #31 on: December 21, 2010, 05:40 PM »
That's because we never use amps in relation to power tools like Americans do. We always use watts over here.
That's because we don't have any warning labels on our power tools like Americans have. We always just use them until they explode.  [embarassed]
Anyway, I don't know what the limit is on the CT's. I know I have used my 2200 watts CS70 on the CTL Mini, the CTL 22 and the CTL 26 without problems.
Offline Ken Nagrod
« Reply #32 on: December 21, 2010, 05:44 PM »
THANK YOU
Offline jmbfestool
« Reply #33 on: December 21, 2010, 05:46 PM »
+1 What Alex said!
I got a personal message from Ken Nagrod asking what the Amps was on it  its on the warning sticker!  I couldnt remember a warning sticker so I just had a look and nope their aint one!  We in europe dont care about that stuff! lol Like alex said bang a plug in and see what happens! Hey we run 240V! You Americans run 115! We clearly dont care we just want more power! Untill health and saftey steps in and makes usgo down to 110V I dont kno why England does not just run 110V such awaist of energy converting all the time with these little transformers on site.
JMB
*********************************************************************** [thumbs up]UK members click me
Offline jmbfestool
« Reply #34 on: December 21, 2010, 05:47 PM »
Oh I see Ken!  You say Thank you to Alex and not me!   I told you der was no sticker!!!!  Instead you tried to make me take my CT apart and have alook inside ! [tongue]
JMB
Offline Ken Nagrod
« Reply #35 on: December 21, 2010, 05:53 PM »
Thanks JMB.  I'll help you put it back together  [huh].
Offline ADKMedic
« Reply #36 on: December 21, 2010, 08:35 PM »
This may be a silly question, but if the tool and vac combination were drawing too much power off of a 15Amp circuit, wouldn't/shouldn't the circuit breaker trip way before there was a fire risk???
Andy
T-15+, RO150, TS55, CT-36, Pro5, DTS400, OF1400, OF1010, PS-420-EBQ, MFK700, DF-500, VAC-SYS, MFT/3 x2, CMS-GE, LR-32, soon a KS-120REB on a date sometime between now and eternity!
Offline Ken Nagrod
« Reply #37 on: December 21, 2010, 08:51 PM »
Andy,
There are usually  a lot of safetys in place.  Most of the time those work perfectly.  There's always the chance something could go wrong since every location is different and not every factor is forseeable.  Wow, I should have been a lawyer!  Get my point?  Play it smart by making sure your safetys work like the breaker and like previously stated, use common sense.  Definitely don't continue if you feel the cords are hot, smell smoke, the tools slow down, etc.  The Festools have protection as well.  And try not to be a worry wart about it.  Otherwise you'll never get anything done.
« Last Edit: December 21, 2010, 08:57 PM by Ken Nagrod »
Offline Rick Christopherson
    • http://www.rts-engineering.com/
« Reply #38 on: December 21, 2010, 11:53 PM »
There is a very good reason why Festool is silent in this discussion, and that is because if they made any comment beyond what is printed on the sticker, they would lose the UL listing for the vac.
The reason for the amperage limitation sticker on the vac is directly related to the UL requirement for vacuums with external power receptacles, coupled with the absence of the NEMA 5-15 to 5-20 adapter tail that was previously available. These conditions mathematically mandate the value shown on the sticker. I won't publicly contradict this mathematical value for the same reason Festool won't. However, someone asked about the internal wiring of the vac and what it could withstand. The simple answer is that the internal wiring of the vac can withstand the full amperage of the circuit without sustaining damage.
Offline Jeff Zanin
« Reply #39 on: December 22, 2010, 07:02 AM »
Interesting comments from Rick regarding the UL considerations.  Now I get why there will never be an official response.
<off topic rant>
This not the first time we have seen unusual outcomes regarding availability, specification, documentation and other non-operational aspects of equipment from UL.  My favorite Festool example of this is the vac sys.
It is hard for me to understand or believe that tools and equipment that not only meet CE requirements but are in regular use in Europe and other parts of the world somehow become unsafe, unsuitable or unsatisfactory when they are "evaluated" by UL for use in North America.  The only explanation I can think of is that the U.S. is a more litigious society and that the UL requirements and process are an attempt to minimize exposure to lawsuits.
I appreciate the concept but I find UL approval less than credible when I look at some of the unbelievably cheap, poorly made, flimsy, flakey, etc. items (many from Asia) that somehow achieve UL approval.  To me this indicates some issues with competence and / or integrity in the process.
</off topic rant>
For the CT36 I can see there may be a different power rating in NA compared to Europe due to voltage differences and "the UL requirement for vacuums with external power receptacles" (ref. UL 1017 4.4.1.4 [ISBN 1-55989-191-2] – it is available online but is copyrighted so I will not provide the link here).
Jeff
