Author Topic: CURED - CT26 cuts out occasionally...normal?  (Read 2373 times)
Offline alschm
« on: September 17, 2017, 12:11 PM »
I'm new to Festool. I'm running an RO90 attached to CT26 in auto mode. Every so often the DC will quit for about 1 to 1/2 second then restart. The RO90 continues to run during this brief time. I'm hooked up directly to 20 amp circuit, so there shouldn't be any line issues. Im using the Sander continuously to remove paint, and this issue with the DC will happen sometimes after 3 minutes of use or not until 10 min of use. There's no rhyme or reason to when/if it happens. The whole system is less than 2 weeks old. Is this normal?
Offline Alex
« Reply #1 on: September 17, 2017, 02:21 PM »
Not normal, contact Festool or your dealer.
Offline ART at WORK
  • Buy less Recycle more
« Reply #2 on: September 17, 2017, 02:52 PM »
My Midi sometimes Cuts out for a few Seconds. I thought at the Start it was the brushes. Then i changed the dust bag and it works again. I think they have a sort of sensor for flowrate or overheating. Change or Empty the bag and then See if you Need the service people.
All the best
Pip
Kapex 120 + UG Set, ETS 150/3, DF 500, RO 90, MFT/3, CTL 36 AC, RO 150, 0F 900, OF 2200, T15+3,  CDD 12, TS 55, A5 Router table, First Aid kit, LR 32 SYS, FS 800, FS 1400/2, FS 1400/2 LR32 FS2 3000, CTL Midi + Cleaning Set, Clamps, Parallel Guides, Centrotec drills, Zobo Forstner set and countersinks, Routers, Systainers, Sortainers, Sys Cart, Syslite
Offline Gregor
« Reply #3 on: September 17, 2017, 08:41 PM »
Overheating should shut it down longer till it starts again, also (IIRC) the CT 26 (and bigger, they only differ in the dust bin) have an extra air path to cool the motor. Airflow sensor is only in the M rated models.
I'm at a loss how changing the bag would remove such intermittent shutoffs, unless the vibration/nudges from taking of the head (to reach the bag) connected a not that connected connection somewhere...
Offline Untidy Shop
« Reply #4 on: September 17, 2017, 09:08 PM »
Check the filters. I know its relatively new and this trouble should not be expected, but you have been removing paint.
Offline antss
« Reply #5 on: September 18, 2017, 10:19 PM »
Quote
Don't bother with service.
 Return it to the dealer and get a new one.  Let them and Festool sort it out on their time.
Offline alschm
« Reply #6 on: September 26, 2017, 07:35 AM »
Thanks everyone. My dealer swapped the unit out for a new one. Doesn't seem to be any issues now.
Offline antss
Re: CURED - CT26 cuts out occasionally...normal?
« Reply #7 on: September 26, 2017, 09:05 AM »
Bravo, this is one of the big upsides to choosing Festool and paying premimum prices.
