Author Topic: Ct Midi Gasket  (Read 3493 times)
Online doug_m
Ct Midi Gasket
« on: January 08, 2016, 10:46 AM »
I bought a CT Midi just before Christmas to beat the 2016 price increase.
I just opened the box this week and found a white gasket ring lying on top of the dust bag.
I have attached a photo of where I have it now. Is this correct?
Thank you Festool for bringing the Midi back to Canada!
Doug
Offline carlb40
  • Site carpenter
Re: Ct Midi Gasket
« Reply #1 on: January 11, 2016, 03:47 PM »
Mine is on site at the moment and i will have a look tomorrow at mine. I don't remember seeing one previously on mine when emptying the bags.
What dust bag are you using?  If it is the long life filter bag, there is a plastic part on that. I wonder if it has come off and stuck to your inlet pipe?
Carl
Never never go, never never know [smile]
Flickr
Online doug_m
Re: Ct Midi Gasket
« Reply #2 on: January 11, 2016, 03:54 PM »
Hi Carlb40,
Its not a longlife bag, just the regular disposable.
Thanks for your help.
Doug
Offline GarryMartin
Re: Ct Midi Gasket
« Reply #3 on: January 11, 2016, 04:35 PM »
Just had a quick look at my Midi (230V GB) and I don't have a gasket there.
However EKAT (the spare parts system) does seem to show a gasket in that position in the diagrams.
Offline mwildt
Re: Ct Midi Gasket
« Reply #4 on: January 11, 2016, 05:20 PM »
My US model does not have one. It does have a little lip though. I see one in ekat as GarryMartin also stated.
Offline SRSemenza
Re: Ct Midi Gasket
« Reply #5 on: January 11, 2016, 06:05 PM »
 @TylerC   Not sure but maybe the gasket goes along with units that are Full Unit Certified HEPA as opposed to the earlier ones that just had HEPA filters?
Offline TylerC
Re: Ct Midi Gasket
« Reply #6 on: January 12, 2016, 09:45 AM »
The gasket fits in a groove on the inside of the CT were it can’t be seen. I believe someone in our service department has contacted the OP.
This account is retired. Please address all Festool questions to @festool usa.
Online doug_m
Re: Ct Midi Gasket
« Reply #7 on: January 12, 2016, 02:35 PM »
Brad from Festool service told me the gasket goes on the inside of the motor housing so the gasket is probably just a spare.
I've had the vac for two weeks and haven't opened up the housing so mystery solved.
Thanks to everyone for your help.
Doug
Online Alex
Re: Ct Midi Gasket
« Reply #8 on: January 12, 2016, 04:41 PM »
But it could also be that it's not a spare but that the original was never seated properly and that's why it fell out. Did you discuss this possibility with the Festool service person?
Online doug_m
Re: Ct Midi Gasket
« Reply #9 on: January 12, 2016, 04:48 PM »
@Alex
Thanks. I will ask Festool if its ok to open up the housing without voiding the warranty and see if there is a gasket inside.
Online doug_m
Re: Ct Midi Gasket
« Reply #10 on: January 13, 2016, 04:46 PM »
Just to update.
I did open the motor housing and saw that there was no gasket inside.
The gasket is now installed correctly.
Must have fallen out during assembly as @Alex had suggested. Thank you very much!
Thanks to Brad at Festool Service and everyone else for your replies too.
Online Alex
Re: Ct Midi Gasket
« Reply #11 on: January 14, 2016, 08:14 AM »
Glad it worked out.
Offline mdn2017
Re: Ct Midi Gasket
« Reply #12 on: April 04, 2017, 06:50 PM »
Hi Doug, I noticed from this post that you opened the motor housing. I have purchased a 2nd had unit and want to remove the hose garage and top hood to clean properly.
Is there anything I should look out for when I open the housing?
Malcolm
Offline Pizza Steve
Re: Ct Midi Gasket
« Reply #13 on: July 07, 2020, 08:08 PM »
@doug_m Thank you for posting!
I just replaced my CT MINI's cracked hose garage and that same white o-ring appeared out of thin air!  I needed your photo to properly put humpty dumpty back together again.
PRO TIP: reassemble your CT & hose garage upside down!  I only realized how to route wires and the foam padding after considerable manipulation of the whole assembly.
