I can tell you that in the reverse, I have had no issues at all. The UK 110v version of the TS60 comes hard-wired, so my first move was the swap the plug itself. I had to wait a few days for the internal connector, but then I switched to Plug-it. The TS60 is a higher amp-draw tool, so if it works fine, the others should be no issue either.
In your case, most of the tools will already be Plug-it, with exceptions for OF2200, RAS115, CT extractors, and really old versions of the tools.
With those exceptions in mind, the simple and most cost effective move is to sell your Plug-it cables while you are still in the US and by a new one that fits the transformer
@woodbutcherbower recommended, when you get to your destination. The beauty of Plug-it is that you really only need one, no matter how many tools you have. If you have several to sell, and only buy one, you could come out ahead, and apply that profit to the transformer.
Hope that helps.
Depending upon what tools you actually have, it could be that easy. If you own any of the exceptions, you have to get new ends for the existing cord.
