Author Topic: Connecting Guide Rails together  (Read 2287 times)
Offline Cathey01
« on: November 29, 2021, 10:45 AM »
I currently own an FS 1900/2.  I’d like to expand my capability by adding an FS 1400/2-LR 32.  Are the two guide rails interchangeable.  Can I use the two different rails connected together to make a longer rail?
SC
Offline SRSemenza
Re: Connecting Guide Rails together
« Reply #1 on: November 29, 2021, 10:53 AM »
    Welcome to the forum  [smile]
     Yes, they are interchangeable and can be connected using the guide rail connectors.
Offline Birdhunter
« Reply #2 on: November 29, 2021, 11:00 AM »
There are several connectors available. A search should turn up a number of posts advocating each.
Birdhunter
Offline 4nthony
    • Slack for Recon Tools
« Reply #3 on: November 29, 2021, 01:02 PM »
I have the Festool connectors and after the first use, noticed the screws dented the rails. I may have tightened them a bit too much, but there are threads here that mention the TSO Connectors play much nicer with your rails.
Recon Tool Notifications
Anthony
Offline Paul_HKI
« Reply #4 on: November 29, 2021, 02:30 PM »
The latest Festool rail connectors are also a good upgrade on the original type:
https://www.festool.com/accessory/577039---fsv2
TKS 80 EBS-SET, KS 60 E-Set, TSC 55 REBI, TS 75, HKC 55,
DF 500 & DF 700, OF2020, OF1010 REBQ, OF1010 EBQ, OFK 500,
T18+3, C18, PDC 18/4, TID 18,
RO 150, RO 90, RAS 115, RTS 400, ETS 125, ETS 150/5,
EHL 65, HL 850 EB,
CTL 26 E, CTL MIDI I, CTL-SYS, CT-VA-20
VAC SYS w/ SE1 & SE2, MFT/3, SYS PowerHub, DUO SYSLITE, & KAL.
Offline jcrowe1950
  • Festool Dealer Affiliate
    • Woodcraft Chattanooga, TN
« Reply #5 on: November 29, 2021, 02:57 PM »
   The denting of the rails is caused by too much torque on the screws....that's why Festool used slotted screws because they were simply designed to snug up firmly, not honk down on them....with steel and aluminum interfaces the steel will overcome every time.....TSO has a really nice solution to that issue.
Festool Specialist at Woodcraft, Chattanooga, TN
Latest Festool purchase...Rotex 150.
Online Packard
« Reply #6 on: November 29, 2021, 03:34 PM »
I recall a friend replacing the "junk" brass split rings that held his camera strap onto his Nikon.  He replaced them with the "much better" stainless steel versions.
In a few months the stainless steel split rings chewed right through the camera lugs.
Nikon did address this later on by sleeving the brass camera lugs with stainless steel sleeves.
This image shows the sleeved lugs.  As I recall it cost him $50.00 to replace the lugs back in the late 1960s.  About $400.00 in today's dollars.
But I would think Phillips head would generate less torque than a slotted head.  I think they chose the slotted head to minimize the use of a screw gun, not to generate less torque.
What would be a "sacrificial" screw for binding to aluminum?  I think making the links with a think strip of stainless steel for the screw to bite into would help.
I was never much inclined to over tighten.  The screws gripped firmly with just a slight tightening.
Offline jcrowe1950
« Reply #7 on: November 29, 2021, 08:48 PM »
    I am just relaying information from either Greg Paolini or one of the other Festool instructors....the small slotted screws can cam out more easily. As always, YMMV.
Offline presidentsdad
« Reply #8 on: December 13, 2021, 12:15 AM »
I have the TSO rail connectors, I like them.  Very easy to use and don't damage the rails.  One of the keys to connecting the rails is that the ends are not guaranteed square, so leave a small gap between the rails to keep the end from messing up the straightness of the rails. :)
PresidentsDad - TS75; FS1900; FS1400 LR32; CT36; RO 150; DF700 XL; Seneca Small Mortise Kit; ETS EC 150/3; OF 1400; VAC SYS System Set, RO 90
Offline Rick Herrick
« Reply #9 on: December 13, 2021, 08:29 AM »
Just an addition to this above.  When joining 2 holey rails, make sure that when you set that small gap, ensure you have not lost your 32mm spacing between holes.
Offline CADru
« Reply #10 on: December 13, 2021, 09:48 AM »
FWIW, before switching to the TSO connectors I used to replace the Festool connector stock set screws with SS Nylon-Tip set screws from McMaster-Carr (part# 93285A412). No more dented rail.
https://www.mcmaster.com/catalog/127/3319
Offline gunnyr
    • Compass Custom Creations
« Reply #11 on: December 13, 2021, 08:36 PM »
I use the Festool Connectors.  I did replace the stock set screws with 3mm allen set screws because I never seemed to have a slotted screw driver handy.  Now I keep a 3mm ball end driver in the Systainer for my TS-55 and HKC-55 saws.
I really don't get the concern about denting or marking the rails.  I simply snug the set screws down and get on with it.  Am I missing something?
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|ETSC 125|DTSC 400|RO 90|RO 150|OF 1400|OF 1010|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|STL 450|DUO-SET|SYSLITE KAL II
