Here ya go - apologies for the formatting:
Note: Prices are in US Dollars
Position | Part No.| Description | Quantity | Price excl VAT | Price incl VAT
1 491852 Armature 110-120V 1 46.51
2 491853 Field assembly 110-120V 1 25.10
3 486317 Switch attachment 1 10.31
4 489622 Socket housing 120V 1 5.59
4 491904 Socket housing GB 110V 1 7.38
5 492158 plug it-cable CN 230V 1
5 496087 plug it-cable JP 1
5 490650 plug it-cable GB 240V 1
5 490649 plug it-cable CAN 1
6 400669 Raised-head screw 3,5 x 30 mm 7 0.78
7 451796 Stripper 1 2.55
8 451371 Bush 1 2.05
9 490207 Gearbox cover 1 45.84
10 228509 Raised-head screw M4 x 12 3 0.78
11 451372 Bush 1 3.51
12 451366 Bending spring 1 0.78
13 451367 Clamping lever 1 4.11
14 400565 Raised-head screw 3,5 x 70 mm 2 0.78
15 457337 Flange bolt 1 1.47
16 490209 Connecting member 1 12.35
17 490210 Lifter rod 1 46.98
18 461987 Wrench 1 6.68
19 228520 Nut; M5 1 0.78
20 458983 Slide 1 10.34
21 490120 Splinter guard 1
22 453082 Washer 1 1.43
23 490212 Slide inlay 1 9.23
24 400062 Screw; M4x7 6 0.78
25 400526 Screw; M5x25 1 0.78
26 489687 Bracket 1 18.06
27 400535 Cheese head screw M4 x 20 2 0.78
28 400008 Needle sleeve 2 2.98
29 490213 Cam 1 20.96
30 451356 Weight 1 18.12
31 490214 Gear 1 18.23
32 490208 Gear housing 1 43.98
33 490215 Gasket 1 8.74
34 455186 Bearing 1 13.77
35 200617 Circlip; A 8x0,8; DIN 471 1 0.78
36 400009 Supporting ring 1 0.78
37 457043 Washer 1 0.78
38 490216 Pendulum drive 1 10.70
39 490217 Holder 1 13.62
40 490218 Pendulum control lever 1 10.96
41 219031 Raised-head screw 3,5 x 10 mm 2 0.78
42 491571 Hard metal holder 1 28.30
43 400678 Cheese head screw M3 x 8 1 1.21
44 453491 Cover 1
45 700077 Absaugstutzen 1 5.29
46 400626 Ball bearing 1 4.91
47 457383 Fan 1 2.05
48 228672 Ball bearing 1 3.50
49 444018 Solenoid ring 1 0.85
50 461985 Air guide washer 1 1.48
51 219069 Raised-head screw 3,0 x 12 mm 2 0.78
52 400524 Raised-head screw 3,5 x 30 mm 2 0.78
53 449640 Motor housing 1 8.93
54 491157 Brush holder with brushes (pair) 100-240V 1 13.73
55 491698 Electronic 110V 1 56.71
55 490222 Electronic 120V 1 56.71
56 451354 Gasket 1 2.46
57 493553 Brush (pair) 110-120V 1 13.73
58 494166 Base 1 15.76
