Author Topic: Best place to get replacement parts  (Read 551 times)
« on: August 10, 2020, 05:15 PM »
I need to get new rods for my of1400 that attach to the edge guide and a new plate for my lr32 system.  Any idea where i can get them?
TS-75, LR32, OF-1400, TSO GRS16PE,  TSO TPG-20, TPG-30, TPG Adapter
Offline SRSemenza
Re: Best place to get replacement parts
« Reply #1 on: August 10, 2020, 06:22 PM »
You can call Festool or a dealer to order parts.
Here is a link to the parts catalog if you want to look up part numbers https://ekat.festool.de/login/jsp/main.jsp?doAction=start&autologin=true&userId=US-Kunde-FT_US&password=Customer
Offline Bert Vanderveen
« Reply #2 on: August 11, 2020, 07:36 AM »
No need to buy the 'original' rods — use threaded rod. Is is a metric size, 6 or 8 mm ( I am currently unable to check…). Advantage: you are not limited by the length.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline Alex
« Reply #3 on: August 11, 2020, 07:52 AM »
Threaded rods? Seriously?  [blink]
« Reply #4 on: August 11, 2020, 07:54 AM »
Yeah, the work as well as the slick ones from FS. (Esp in a cinch… : ))
On order: … [ ! ]
Offline Alex
« Reply #5 on: August 11, 2020, 08:02 AM »
I wouldn't mind to use them in a pinch, but with longer use I would think they'd cut into your router's base.
Offline grobkuschelig
« Reply #6 on: August 11, 2020, 09:24 AM »
I bought stainless steel in 8mm(? This was for an OF1010, not sure of the OF1400 has the same diameter rods..) to make „custom length“ rods from the local hardware store.
Works great and gives a cheap, but lasting option for any desired length.
