Author Topic: Anti-Static or Non-Anti Static Hose  (Read 2210 times)
Offline Pompeio
« on: January 11, 2020, 09:10 AM »
Am I good to go to run a shortened non-antistatic hose from my Kapex to the CT26 without fear of damaging any electronics/circuit boards if I do not live in a low humidity environment?
Thank you.
Re: Anti-Static or Non-Anti Static Hose
« Reply #1 on: January 11, 2020, 11:23 AM »
Was the idea of static damaging circuit boards ever acknowledged by Festool to be anything more than apocryphal?
The new inexpensive vac (CT 15) is being shipped with a non AS hose. Does that mean static is not an issue with circuit boards or has the design been improved to protect them?
I’ve used a non-AS cyclone with a first gen CT Mini for a decade.
Offline threesixright
« Reply #2 on: January 11, 2020, 12:16 PM »
I think the electronics are correctly grounded anyway.  That’s not where the hose is for.
The AS hose is only there (disclaimer: my thoughts) to prevent  potential dust explosion, since its possible your hose gets static charged (because of friction).
« Reply #3 on: January 11, 2020, 12:19 PM »
For a stationary setup I don’t see any problem with using the non-AS hose.
Just a side note, even when the conductive path is not continuous, as in my old Mini/cyclone setup, I still get some substantial benefit from using an AS hose to the cyclone compared to the non-AS hose. There is less shocking but more importantly to me, less build up of dust on the outside of the hose.
I wouldn’t take a used non-AS hose into a finished home.
Offline SRSemenza
« Reply #4 on: January 11, 2020, 05:02 PM »
Considering that Festool sells non-AS hoses to be used with there vacuums there should be no problem with regard to the OPs question.
Offline Alex
« Reply #5 on: January 11, 2020, 05:15 PM »
It is to prevent the user from getting shocked when you touch the hose. It is a mild shock, but still pretty irritating. I feel it often. I use my non-AS hoses often, but it also happens sometimes with the AS hose, probably because the wall socket isn't properly grounded.
You don't need to live in a dry climate to get static build up, I live 3 km from the coast line of the North Sea, and we have a very high air humidty here.
I've never seen any adversary effect on my vacs though.
Offline Steve1
« Reply #6 on: January 13, 2020, 08:19 AM »
If the static potential is enough to give you a shock, its enough to create a spark.
I am sure Festool does not want their customers shocked, but I expect they are far more concerned with possible fire and explosion hazards.
https://www.workplacesafetynorth.ca/sites/default/files/opt%20Webinar-Canadian-Combustible-Wood-Dust.pdf
Offline Pompeio
« Reply #7 on: January 13, 2020, 11:05 AM »
Just wanted to thank everyone for their responses!
