I have 2 bandsaws, one large floor standing model and a smaller bench model. I tried cutting a Jowat puck on the smaller model that has a 1/4" blade with 4 tpi.....it took about 3 attempts to cut through the 63mm dia, having to stop and clean the blade, bandsaw wheels, rollers & guides...a right b l o o d y mess! There would be no way you could use the bandsaw blade again without major cleaning.....The blade starts to adhere itself to the bandsaw wheels etc, etc as the adhesive cools down....
The glue starts to soften/ melt at about 95 degrees and as the cut proceeds, more adhesive gets stuck to the blade, then more heat is produced and the problem gets worse & worse.
It's a single speed bandsaw, so I cant slow the blade down......I was thinking of ordering a blade with fewer teeth and try that after the puck had been in the Freezer overnight.
I'm sure I saw the pucks on the Jowat site that stated they offered a " Colourless" puck...?? Perhaps the colourless is only available in pellet form and I was mistaken...?
I dont tend to use my Conturo every working day, but have needed to use it quite a lot more recently......Hence, I've been getting through more pucks and the need to cut more down.
I like the idea of a large static edgebander, but it is hard to justify the additional expense at the moment.
