Author Topic: 50mm hose for boom arm  (Read 3186 times)
Offline Naildrivingman
« on: December 23, 2017, 05:50 PM »
Wondering if anyone can help locate part number(s) for the short (~1.5m x 50mm) hose that comes with the boom arm kit.  I would like to purchase this hose for use with my tablesaw and CT26. I have the boom arm, but would really like to have an extra hose in the event my boom arm and table saw are set up simultaneously.
Ekat lists it as a catalog item and I see no reference to it in the catalog. I do see a 3.5m x 50mm version, but would rather not buy that only to cut it.
Thx.
Dance with who brung ya...
Offline ishmerc
Re: 50mm hose for boom arm
« Reply #2 on: December 23, 2017, 06:34 PM »
here
https://www.festoolusa.com/accessory/452888---d-50x2,5m-as#Overview
Thanks @ishmerc I missed that one.  I can’t seem to navigate the online catalog correctly.  Could you reply with the pathway to the hose section of the online catalog?  Thanks!
Offline Peter Halle
« Reply #3 on: December 23, 2017, 06:54 PM »
Just because I was checking in, here is the portion in a screenshot"
« Reply #4 on: December 23, 2017, 07:41 PM »
Thanks all.  I was hoping to find the 1.5m version.  I don’t want 8’ of hose. I’ll probably buy this plus two extra connectors, cut the pipe in half and end up with two 50mm hoses. Appreciate the help.
Offline Tom Gensmer
« Reply #5 on: December 23, 2017, 09:13 PM »
Call up Oneida Air Systems and have them sell you a 5’ (or whatever length you want) section of their 2.5” reinforced vacuum hose. It is static conductive and has a smooth inner wall so you get great air flow. The hose ends are the same size as standard Festool hose ends and are fully compatible with the Festool system.
https://www.oneida-air.com/inventoryD.asp?item_no=AXD250066&CatId={4B13252A-6488-4E29-BAA2-E5CBD09B1DA5}
« Last Edit: December 23, 2017, 09:31 PM by Tom Gensmer »
CT-MIDI, C-18, RO-150, RO-90, OF-1010, OF-1400, MFK-700, MFK-700EQ/B, EHL-65, DTS-400, LS-130, MFT/3 (x4), MFT/Kapex (x3), KA 65 Conturo, endless Systainers
Offline GarryMartin
« Reply #6 on: December 24, 2017, 06:01 AM »
You can buy the hose per metre, and then add the required ends. That's what is listed in the EKAT diagrams.
Festool 452896 Antistatic rotating adapter - D 50 DAG-AS (you'll need two, one for each end)
Festool 452386 Suction hose D50 antistatic - D 50 MW-AS
Problem is, you're still going to end up with either 1m or 2m as you can't buy in smaller increments that 1m...  [sad]
And then you might find that the 2.5m hose linked earlier works out cheaper, even if you chop some off.
Online rst
« Reply #7 on: December 24, 2017, 08:34 AM »
I'm with Tom G. regarding Oneida Air, I have three steel dust deputys, their Festool version sitting on a Midi, and also about a dozen of their non conductive angle and straight connectors.
Offline pettyconstruction
« Reply #8 on: December 24, 2017, 11:57 AM »
That’s really cool, I wonder if that hose would help the kapex?
Charlie
Offline ben_r_
« Reply #9 on: October 31, 2018, 12:00 PM »
Bumping this thread as I am looking for a replacement hose for the 50mm that comes with the Boom Arm Kit. Considering that Oneida Wire-Reinforced Vacuum Hose. The price is just too good to not. So for those that have gone this route, just to confirm, the fittings on that Oneida hose work with the input of a CT vac AND the vac end of a Festool hose?
Online rst
« Reply #10 on: October 31, 2018, 06:28 PM »
I have numerous Oneida hoses and they all have the same vac ends and work with the Fein, Festool, and Metabo vacs that I use.
« Reply #11 on: October 31, 2018, 07:56 PM »
I bought the Oneida 50mm x 1.5m hose. It works great!  I think the secret is that the end is tapered ever so slightly, so it will not only fit a typical shop vac, but also the CTs and everything else I have tried.  The other thing I really like is the extreme flexibility. I strongly recommend this route.
Offline ben_r_
« Reply #12 on: November 01, 2018, 11:58 AM »
Thanks guys! Just what I needed to know!
