Author Topic: 125EQ running rough  (Read 2542 times)
Offline dminnery
125EQ running rough
« on: September 22, 2014, 11:35 PM »
my 3 year old sander has been running rough for the past month.
Intermittently, it tends to start up and vibrate and whine. Then when I touch it down to a flat surface it grabs the wood is hard to control.
I'm not sure what's wrong, but it needs servicing. I'm trying to determine if this is worth servicing, not sure what it will cost to fix.
It's seen moderate use.
thanks,
David
Offline SRSemenza
Re: 125EQ running rough
« Reply #1 on: September 23, 2014, 01:19 AM »
thanks,
David
Call Festool service. They will certainly be able to help you determine what to do about the problem. # in my sig line.
Offline dminnery
« Reply #2 on: September 23, 2014, 01:31 AM »
Thanks Seth!
Offline Festool USA
  • Festool USA Employee
    FOG Administrator
    • Festool USA
« Reply #3 on: September 23, 2014, 09:37 AM »
It could be a damaged pad brake or the plastic on the back of the pad could be cracked. But, like Seth suggested, a call to the service team would be best. They'll be able to help diagnose it over the phone.
Shane
Offline dminnery
« Reply #4 on: September 23, 2014, 10:18 AM »
Thanks Shane, will do.
Offline Alex
« Reply #5 on: September 23, 2014, 12:10 PM »
Sounds like the pad brake is worn. Would be a cheap fix.
