Author Topic: 125 EQ 5" replacement sanding pad  (Read 1743 times)
Offline DaveC784
« on: June 25, 2021, 02:48 PM »
Need a replacement sanding pad for a Festool 125 EQ 5" sander serial number 13011376.  Tried the spare parts look up, but not clear which pad fits my sander.  I live in Florida and the heat and humidity completely destroyed the foam in the sanding pad.
Offline Alex
Re: 125 EQ 5" replacement sanding pad
« Reply #1 on: June 25, 2021, 03:09 PM »
https://www.amazon.com/Festool-492280-Jetstream-Replacement-Sanding/dp/B002VMVG76
It is not the heat and humidity of Florida that destroyed your pad, they deteriorate on their own due to the chemicals used in it.
Offline DaveC784
« Reply #2 on: June 25, 2021, 04:16 PM »
Thanks Alex.  I looked at this one, but not sure it would fit since I could not find ETS anywhere on the sander.
Offline squall_line
« Reply #3 on: June 25, 2021, 04:28 PM »
Is it a Pro 5?
Do you have a picture?
Offline Crazyraceguy
« Reply #4 on: June 25, 2021, 06:47 PM »
Really? I have never heard this before. How long does this typically take?
My original RO90 was well over 5 years old and before the fire killed it, had never showed any signs of deterioration. The ETS EC 125 was only about 2 years old then too. I didn't use it as much as the new one I have now, but if time is the factor, that shouldn't matter that much.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
MFT clamps set
Offline Alex
« Reply #5 on: June 26, 2021, 01:19 AM »
You say 125 EQ in your title, and that can only be the ETS 125 EQ.
Since you want exact information, why don't you tell us exactly what's written on your sander? Pics would be nice too.
Yes, really. Can take between 5 to 10 years, but it will happen eventually. Happened to loads of pads of mine, and other people mention it here often too. Like in this post.
Offline Vondawg
« Reply #6 on: June 26, 2021, 06:32 AM »
Also…I think if you are sanding (just about) “anything” or say a painter, the pad gets exposed to a lot of “stuff”…as compared with use in strictly say, a cabinet shop, where it’s only sanding new wood
« Last Edit: June 26, 2021, 06:34 AM by Vondawg »
Offline Alex
« Reply #7 on: June 26, 2021, 08:23 AM »
That can destroy your hook & loop and surely has to be figured in, but the foam deteriorating is purely due to a chemical reaction inside the material. To give the foam its elastic properties certain additives are added that eventually destroy the molecule bond.
« Reply #8 on: June 26, 2021, 11:24 AM »
The disintegration issue has happened to me with Festool, Dewalt, Milwaukee and Porter Cable. The interesting thing is that the oldest sander I own, a National Detroit DA that's over 40 years old is still fine.  [huh]
Offline allthegearnoidea
« Reply #9 on: June 26, 2021, 12:42 PM »
I've got pads from sanders I've personally had for 20+ years and ones I've inherited even older. Never had this problem of them spontaneously decomposing. Maybe it happens with some or certain compounds but I wouldn't think of it as an inevitable conclusion for any and all pads. Environment will definitely have an impact too, warm damp/humid climate will cause anything to decompose faster than a colder and drier one. That's just basic physics not unique to sanding pads.
« Last Edit: June 26, 2021, 01:05 PM by allthegearnoidea »
Offline Alex
« Reply #10 on: June 26, 2021, 01:57 PM »
I've had sanders from Rupes, Metabo, Bosch, Black & Decker and Festool. And it only happened to me with the Festool sanders, and with lots of them, the RO150, ETS 125, DX93 and RTS400.
I had one sander of Black & Decker, and I only had to replace the pad after 16 years because I made the mistake to start sanding without sandpaper on it and the hook & loop was destroyed. And for a hobbyist brand, that sander was a darn fine one and lasted me longer than any of the pro brands. It lasted 18 years, while the others never lasted longer then maybe 10. Only Festool might challenge that, but I don't know yet as I have my longest owned Festool, the RO150, for only 12 years now.
As for humidity, that has no influence on plastics. Higher temperature makes molecules move faster, and thus makes chemical reactions happen quicker, but I doubt a handful of degrees adds a lot in this case.
« Reply #11 on: June 26, 2021, 05:56 PM »
(Attachment Link)
That 40 year old unit is very likely to use PSA paper and I'm sure a different type of pad composition.
But yeah, I have had older ones that never experienced his degradation either, but again old. They were not a soft/flexy as the newer ones.
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
MFT clamps set
« Reply #12 on: June 27, 2021, 09:58 AM »
Ya you're correct it does use PSA paper, also the pad is a harder durometer and it's thinner so there's less to deteriorate.
Offline squall_line
« Reply #13 on: June 27, 2021, 07:12 PM »
This sort of things happens to the soles of basketball shoes and other athletic shoes all the time, too.  I have a friend who collects (used to collect?) Nike Air Jordans.  One pair he stored in a perfectly normal, climate-controlled area, never wore them, and they never saw UV light.  The soles fell apart in his hands when he went to take them out of the box 10 years later because the polyurethane completely degraded.
