Author Topic: Dining table in stained white oak  (Read 20906 times)
Offline Falch
« on: May 10, 2013, 11:42 AM »
Hello good people.
Just thougt i would post first of many projects done, and on the horizon. I took the step and started my own little furniture bizniz in my basement workshop, and this table, among other stuff (will post this also), was the first to be delivered to my first customer.
It is made of white oak, stained with Osmo walnut poly-x oil.
The dimensions are, 180x90x75cm, and with the extension wings it becomes 280x90x75cm.
The legs are curved a bit, and the edges are curved from the edge, 80mm inwards undeneath. This gives the impression of a table with a curved, and impossibly thin tabletop. The tabletop is realy 45mm solid oak, reinforced with 25x15 aluminium profiles (see picture), the legs are initialy 90x90mm but curved down to 45mm where the legs touch the floor, fastened with Zipbolt connectors. The extension slides are also aluminium.
And also this design was inspired by another persons design, i am not claiming it mine. I only made it, with some tweaks.
86506-0
86508-1
86510-2
86512-3
86514-4
86516-5
86518-6
86520-7
so yeah.. Cheers :)
Offline noob
Re: Dining table in stained white oak
« Reply #1 on: May 10, 2013, 12:24 PM »
Beautiful!
Do you have pics of the table you were inspired by?
Offline Falch
« Reply #2 on: May 10, 2013, 12:37 PM »
It is a danish design page, it is hard to link to the page, but here, this is the picture one the site. ( witch is http://snedkergaardenthem.cloud9.tangora.com )
86550-0
I saw it in a design furniture shop and was blown away by the genius in curving away the tabletop.
Offline cliffp
« Reply #3 on: May 10, 2013, 01:04 PM »
That is a beautiful design and execution. I like the way the table extends - it looks a lot easier to do than mine!
T15+3 set, CXS set, Centrotec set (2011), TS55REBQ, TS75EQ, 1400 rail, 1900 rail, 1400 LR32 rail, LR32 set, MFT/3, OF1400, OF1010, Guide rail adapter, edging plate, angle arm, chip catcher, small bore base, MFS400, MFS1000 profiles, RO90DX, RO150, ETS150/3, Domino DF500, Domino assortment systainer, CTL Midi, compact cleaning set, CMS GE, TS75 Module, OF Module, VL and VB extensions, LA Stopper, Sliding table, Carvex 420 Li 18 GG, core maker set, EHL65EQ, Syslite.
Offline Falch
« Reply #4 on: May 10, 2013, 01:09 PM »
Thanks :) Because of the tabs on the "wings", and the 45 degree angles on the extension bars that mates to the slots on the "wings" they are rock solid and can only slide in and out one way. Gravity baby!
Offline honeydokreg
    • honeydokreg@aol.com     email address
« Reply #5 on: May 11, 2013, 08:06 PM »
Very well done !!  Chow time !! Well how do they say it in Norway when it's time to eat??
Thanks for sharing !!!  Great job again
pay attention to the details.... they make the difference... festool does
www.builtinking.com
youtube channel:  builtinsbykreg
Offline jeep jake
« Reply #6 on: May 11, 2013, 08:35 PM »
How did you cut the sides of the table.
Offline Falch
« Reply #7 on: May 12, 2013, 04:04 AM »
Thanks allot! :) We say "Nå er det mat" or "spise tid" or maybe just "mat" :)
You mean the curves? If so, i drew the curves out on both sides (the bottom and side of the table), used my dozuki saw and cut almost to the lines, and then using a mallet and a chisel i chopped out all the pieces and started to sand with 40grit paper in my bosch random orbit sander...i was sooooo close going out to get a rotex 90..next time :D
Offline Falch
« Reply #8 on: May 12, 2013, 04:51 AM »
The hardest part was actualy making the strongest possbile connection between the legs and tabletop. since i did not have any skirting i was unsure how the legs would hold up to sideways motion, especially since the tabletop, being solid oak, 45mm thick, weighed around 100kg.
This is was i came up with:
86680-0
This mates into
86682-1
This
Pared with 2x dominoes and 2x zipbolts, (8mmx90 half newel connectors) pr leg, the result was solid.
Offline jmbfestool
« Reply #9 on: May 12, 2013, 06:09 AM »
Thanks for posting joint construction.
I was looking at how did you join the legs to the top.
I could see the zip bolt holes just wondered about the angle joint.
Nice!
*********************************************************************** [thumbs up]UK members click me
Offline Falch
« Reply #10 on: May 12, 2013, 06:14 AM »
I am working on some caps for the holes, just have to find a way to make some removable caps that are thin enough, and solid enough for removal.
Offline jmbfestool
« Reply #11 on: May 12, 2013, 06:49 AM »
Oh so u have not glued the legs then.
You are making it so the table comes apart.
I thought you would of glued it like.
I'm not sure what you can make which would look discreet but yet removable to cover the holes.
Offline Falch
« Reply #12 on: May 12, 2013, 07:57 AM »
yeah, i had to make it come apart, was dificult to move with the legs on, especialy out of my shop which is in my basement, through a couple of narrow doors and a shody narrow staircase..
I am working on a jig, so that i can use the router with some guide bushings to first rout a 30mm dia disk, and then route a lip 1,5mm on that disk leaving a "plug" 27mm dia with a lip around it. And then just running it through the tablesaw or bandsaw to cut the plug out.
Like this:
86692-0
Edit: The hole for the zip bolt in the leg is 27 :)
Oh yeah, and the leg curves slightly so it has to either bend, or have a slight curve on the lip...
« Last Edit: May 12, 2013, 08:00 AM by Falch »
« Reply #13 on: May 12, 2013, 08:06 AM »
SWEET! [thumbs up]
Mike
"The only lessons I've learned worth remembering, were when things weren't going well"
"Who is John Galt?"
Offline Rob-GB
« Reply #14 on: May 12, 2013, 09:55 AM »
I really like the style of this table and the leg joint system is both well thought out and looks great. [smile]
Thanks for posting it.
Rob.
Problem? No such thing! Only a solution waiting to be found:- RJ
"A $2 guppy swims......" Deke
Offline honeydokreg
« Reply #15 on: May 13, 2013, 07:38 PM »
Wow great job. Love the design
www.builtinking.com
Online deepcreek
    • TimberFire Studio
« Reply #16 on: May 13, 2013, 09:34 PM »
I'm impressed with the design.  Nice job!
Joe Adams
TimberFire Studio
Houston, Texas
Offline doc4som
« Reply #17 on: May 14, 2013, 12:54 AM »
This is a remarkably elegant table. Congratulations on the build. I  bought a  similar table 30 years ago and still love it.  Now that I have started to hobby woodwork  I was considering to copy and make one slightly larger. But this design is much more elegant. The undercut curves & the narrowing legs define it. Could you send more pictures ,diagrams & explanations on the leg to tabletop joints?
Offline Tom Bellemare
  • Inactive Member
    • Tool Home LLC
« Reply #18 on: May 14, 2013, 01:24 AM »
I love it!
EDIT:
So does my wife!
Tom Bellemare
Customer Svc
Tool Home LLC
www.tool-home.com
512-428-9140
Offline Falch
« Reply #19 on: May 14, 2013, 03:08 AM »
Doc4som: sure, i will post some more pics, i can even post the sketchup file if you want :) will do it later today :)
Tom: Thanks! And sorry (?  [tongue] ) i know the feeling/what happens when the wife likes some furniture and knows i can make it  ::)
Offline jmbfestool
« Reply #20 on: May 14, 2013, 04:14 AM »
I get that from my Missus family!!
The cheapos!!!
They often come up to me for silly things like a wooden coat hangers or something.    Not because they can't find the one they want or  they want one bigger or it needs to fit some where specific but because it cost £25 or something and think I can make the same cheaper.
I tell them to stop being cheap bastards and either get a cheap one or just pay for the one you want because ill be charging you double or more.
Offline Falch
« Reply #21 on: May 14, 2013, 12:59 PM »
So here goes, my work sketches for the table, the whole shabang :)
It is all in metric, but i guess if you have your sketchup tuned to imperial it will convert itself.
86766-0
* Leg joint.skp (69.86 kB - downloaded 203 times.)
86769-2
* Dining table.skp (30.96 kB - downloaded 163 times.)
86772-4
* extension system.skp (50.59 kB - downloaded 201 times.)
« Last Edit: May 14, 2013, 04:31 PM by Peter Halle »
Offline Falch
« Reply #22 on: May 14, 2013, 01:04 PM »
The sketches are a bit rough, some of the curves are hard, or impossible to draw considering sketchups strongly geometric rules, but you get the drift.
Just ask if there is anything :)
Edit: oh, if a mod has a second please tune the post (i am not sure what i did wrong), somehow the last pic became a thumb and stuff got a little mixed :)
Offline doc4som
« Reply #23 on: May 14, 2013, 02:12 PM »
Oh, thank you so much for the sketches. Right now I have a long learning curve to follow to achieve your expertise. Will be trying to practice the joints with scrap wood until I am successful. I did not want this post to go dormant before I got as much info on how to build this gorgeous table.I am online right now and is 1.10 in the afternoon (pm) in central USA (Minnesota). I see you are online also. What time is it now over in Norway where you are?
Offline Falch
« Reply #24 on: May 14, 2013, 02:20 PM »
i will keep it alive, if not just shoot me a pm :) not beeing overly sure about am/pm (you freaks  [tongue] ) it is 2018 here so i guess it is 8.18 pm :)
Offline GhostFist
« Reply #25 on: May 14, 2013, 04:24 PM »
Awesome job on the table! You've got good taste and extreme talent
Offline jacko9
« Reply #26 on: May 14, 2013, 08:47 PM »
Fantastic work and just like a guy, you photo it with your laptop instead of a place setting [wink]
Jack
Offline Scdavidson
« Reply #27 on: May 25, 2013, 12:07 AM »
Great table! The lines are awesome... [thumbs up]
Offline aosty
« Reply #28 on: February 01, 2014, 02:24 AM »
Table looks awesome.
How did you the interfacing joints?
More specifically, the square "pocket" at the top of the leg and the V intersection at the outer corner of the top.
(Attachment Link)
This mates into
(Attachment Link)
This
Offline NYC Tiny Shop
    • jamesfinndesign.com
« Reply #29 on: February 01, 2014, 03:14 AM »
An elegant design, well executed! Good luck with your new biz. Thanks for posting.
« Last Edit: February 03, 2014, 11:17 PM by NYC Tiny Shop »
